Question about SAMTRON 55V 15" CRT Monitor
Replacing vga cable
Help me to idantify d pin conector and cable colour code
  • sivapt Jun 20, 2008
    my vga cable is disconnected. Is there any chance to replace it if there is a solution please told me about that
    Scholar:
  • 42 Answers
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Posted on Mar 27, 2008
SOURCE:
Color of wires
Hi Red, Sorry to tell you this pal, but the Toyota's we have worked on do not have a colour coding format for most of the wiring loom. A cable which is loomed from the speed sensor can be one colour going in and another colour coming out because Toyota join cables of any colour, presumably for cost effectiveness. The cable can be identified from the pin number inside the management computer, or by downloading a pin out diagram from <www.allpinouts.com> Regards John.
Oct 06, 2012 | 1996 Toyota RAV4
How to connect the front penal with motherboard
Hi.
To connect the front panel of your case with your motherboard, it is quite easy.
If you have the motherboard manual, I will help you on connecting the cables to the motherboard.
In summary, the pins or connectors for the front panel are on the same spot of the motherboard.
If you don't have the manual, check on the motherboard, THere are like 8 or 10 pairs of pins which are labeled.
The speaker cable is a 4 pin conector. See the speaker's pin on the motherboard.
The Power cable will fit into a 2 pin connector.
The HDD Cable as well
The reset. too..
The colored cable is always +, the black cable is always -
The + usually goes on the first pin of the assigned connector.
For example: motherboard connector is:
The cables goes on the Jumpers area.
You will see somthing like this:
Hope that helps
God Bless You!!
Remember to rate this solution!!
Feb 21, 2011 | Intel Motherboard
Word clock /midi connector pinout
1: MIDI OUT 1(PIN 4)
2: MIDI OUT 1 (PIN 5)
3:WORDCLOCK OUT (GROUND)
4:MIDI OUT 2 (PIN 5)
5:MIDI OUT 2 (PIN 4)
6:MIDI OUT 1 (PIN 2)
7: -
8:WORDCLOCK IN (LIVE)
9:WORDCLOCK IN (GROUND)
10: MIDI OUT 2 (PIN 2)
11:MIDI IN1 (PIN 4)
12: MIDI IN 1 (PIN 5)
13: WORDCLOCK OUT (LIVE)
14: MIDI IN 2 (PIN 5)
15: MIDI IN 2 (PIN 4)
That's it!!!
I had the same problem as you and this was the first web I saw. I was looking for it in other webs but, nothing...at least the guy who selled me the Terratec mic8 ews found the cable, so I believe that i had a matter to help people that has the same problem as me!
Cheers!!
Apr 08, 2010 | TerraTec Electronic EWS MIC8 Sound Card
How to wire acoustic solutions AS134
how many cables shud link up to the tv with the acoustic solution model AS134?i have the colour coded pins plugged in to the speakers left,right,back left,back right and center which plug in to the subwoofer box.how ever i then only have 1 cable left which has a red pin and a white pin that i assume go into the AUX left and right pin ports?the cable then splits into another 2 red and white pins.do these pins plug into the left and right output on the tv?am i missing any cables?help would be appreciated.
Jul 19, 2009 | Acoustic Solutions Audio Players &...
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
I have an IT8705F 011-BXA MA89F0 Motherboard and am trying to install a WD2200AAKW hard drive with a serial 2.0 cable. Is this possible and if so, where on the motherboard does the connector cable attach?
the connector is coloured check the board, u will see a cable connector they are three in number two has thesame colour and the other that is different is the hdd conector, if not the system must be sata
Jul 16, 2009 | Computers & Internet
No connection to internet
There are 2 common colour codes for Cat5e. In Australia the most common is T65A Colour code for this is below
Pin 1 is Green T3
Pin 2 is Green R3
Pin 3 is Orange T2
Pin 4 is Blue R1
Pin 5 is Blue T1
Pin 6 is Orange R2
Pin 7 is Brown T4
Pin 8 is Brown R4
A very good link for this is http://www.grech.net.au/networking/utp/index.html
Hope this helps,
Cheers,
Jason
Apr 23, 2009 | Computers & Internet
CPU fan that cam togther with my CPU has 3 pin conector, but the motherboard has 4 pin Conector. That dosent sems to work ut
The extra pin on the motherboard is for a speed sensor connection which your fan does not have. The plug on the fan cable has two plastic tabs which fit over a tab on the motherboard connector. Just line the tabs up and the plug will fit properly. The fourth pin on the motherboard just won't be used with your fan.
Dec 14, 2008 | Computers & Internet
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
419 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
