Question about Vacuums
The KP1010 was at rest all winter long. It has worked beautifully before this. It is now working but we can't stop it from brewing. It works but it delivers the water at the rapid cycle. We have water all over the place. Is there a way to fix this?
    President:
  • 512 Answers
Sounds like the flow meter is stuck open, letting water keep running. Go to www.krupsusa.com. Then to parts, then pick your model number, this will give you all parts for you machine. Also click on schematics and it will give you a breakdown for your machine and where all parts are located. First see if you can try and take flow meter apart, maybe it can be cleaned.
Posted on May 08, 2010
Power nozzle does not work. Light comes on on power nozzle but it does not vacuum
Many early version PN-2E power nozzles have reset buttons that are becoming faulty. The factory stopped adding the rest button to this model power nozzle so you can update your unit by removing and this my solve your issue. You have the trigger to stop the motor if you have an issue so the rest button has become unnecessary.
Mar 28, 2015 | Rainbow E series Canister Wet/Dry Vacuum
We bought this inepensive coffee maker at Target. It made one pot, and then quit. The "on" light was illuminated, but nothing happened. No brewing action and no heating of the warming plate. We...
YES THE ONLY THING YOU DID WRONG IS BUYING THIS CHEAP STUFF(MAYBE ITS SOME CHINESE STUFF) IF POSSIBLE CHANGE THIS WITH SOME BRANDED RELIABLE PRODUCT. ITS BETTER TO WASH YOUR HANDS OFF THIS IRRITATING STUFF.
REGARDS.
PLZ. RATE THIS
Jul 05, 2011 | Vacuums
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
Problem is you can have the maker plugged in but you can't manually brew the coffee. The switch will not engage to brew the coffee. Stainless Steel, Programmable Cuisinart CUI DCC 2000 model.
I have this model.
I'm not sure if you mean if it won't brew manually or not at all.
Ours failed because the thermistor failed due to the fact that the heater element was badly calcified (calcium deposits). It would come on for a bit, then stop brewing... then it just stopped altogether. I replaced the two thermistors that are in series and it works fine.
The bad news: Cuisinart cruelly used security screws to thwart repairs. The screws are on the bottom and deeply recessed. Thus aside, this coffeemaker is a bugger to dismantle but it can be done after you remove the screws.
Being that I had nothing to lose, I drilled these out and replaced them later.
Jan 07, 2011 | Vacuums
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Loss of suction
have you examined the hose to see if it is plugged. take a broom handle and gently push it thru the hose if it doesn't have bends in it.
Robert
Sep 01, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
