Question about Mustek A3 USB Flatbed Scanner
When I load the CD for my Mustek USB 600 scanner, using Windows 7, it starts by asking me to select my language, and then promptly tells me that the software will only run under Windows 98/ME/XP. Windows 7 has downloaded the drivers, but it's the actual Mustek software that isn't running under Windows 7.
    Sergeant:
    Champion:
  • 236 Answers
Go to the Mustek web site
or
copy the entire set up cd to your hard drive into a folder, then right click on the setup file, select properties, then the compatibilty tab, then check the box "run as" and select the compatable version
Posted on May 08, 2010
I need to download a Mustek SE A3 USB 600 PRO Driver for Windows 7 for the device which got lost.
Hi anderoland
There is no support at Mustek's for Windows 7 . You can't use your device under this OS .
best regards ,
fanaudi .
Sep 02, 2011 | Mustek A3 USB Flatbed Scanner
Mustek Berapaw 1200CS driver for windows 7
There are no Windows 7 drivers for that scanner but you can try this trick:
Download the newest XP drivers from this site:
http://www.mustek.com/mustek/supportdrivers.php
Get the one file installation.
You will not be able to install the drivers but you can trick them to work.
The procedure is simple:
Do not plug in the scanner, start up the
Empty your systemrootwindows emp folder
Srart the instalation and when it asks "Select Language" stop there. Then copy the all contents (files and folders) of WindowsTemp to another folder (e.g. systemroot1)
Then plug in the scanner and windows should be able to find the drivers there if not guide it to that location and let it install Mustek Twain drivers.
Enjoy your scanner.
Feb 28, 2011 | Computers & Internet
UPDATE DRIVER FOR SCANEXPRESS 600 PRO FOR WINDOS 7
ON THIS PAGE:
http://www.mustek.com.tw/Support/
select suport, enter your model ( SCANEXPRESS 600 PRO ) --> search
click on ScanExpress A3 USB 600 Pro
click on drivers download, select driver for your operating system and download.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 26, 2011 | Mustek A3 USB Flatbed Scanner
Can't select OCR language in settings for Mustek 1200 UB Plus usb
the mustek pb1200 ub is the same as the packard bell bear paw 1200 try the software for that
Aug 05, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Can I install the Mustek 600 usb scanner to a windows xp?
this is not compact able with Xp but you can try this it may work or not ................
Everybody who ownes a Mustek 600 II N scanner and want to install it under XP will notice it won't work. Mustek's website says the scanner is not supported under Windows XP.
I've tried this and it works fine here:
- Download the NT4 driver from http://www.mustek-europe.com/eng_/html/treiber/scanner_P_n.htm (select the exact drivers by looking up the first two letters of the serialnumber found under the barcode on the backside of the scanner)
- Before installing the driver click right on the .exe file and go to properties, compatibility and select 'Windows NT4' from the pulldown menu.
- Now install the drivers and it should work. I'm running Windows XP PRO here but i'm sure it will work under XP Home too.
If you own another, unsupported Mustek scanner you can try the same. Maybe it will work.
good luck................
Jun 11, 2008 | Office Equipment & Supplies
Need to get driver
i have a driver for mustek 600 cp. pls. send me your email ad.
Apr 16, 2008 | Mustek Plug-n-Scan 600 CP Flatbed Scanner
Mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Feb 07, 2008 | Mustek A3 USB Flatbed Scanner
Mustek Be@rPaw 1200 cs scanner/Vista OP system
Very simple: download from Mustek site ONLY VPDriver.exe. Then open it and store files in a directory. Open Hardware directory on System properties, locates the unistalled item related to USB scanner, select reinstall drivers and point to the directory previous. Vista locate drivers, intall them and our scanner runs correctly with all programs (ex. OpenOffice Draw, etc).
Try it ...
Dec 31, 2007 | Mustek Be@rPaw 1200CS Flatbed Scanner
Mustek A3 USB Flatbed Scanner Logo
146 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
