Question about Olympus VN-2100PC Digital Voice Recorder
ERR display I have an Olympus Digital Voice Recorder VN03100PC. It started beeping when it was near my mobile phone and is now displaying ERREL. I am in the middle of PhD fieldwork and need to retrieve the files. Is this possible?
  • k325700 Apr 14, 2008
  • Anonymous Jun 23, 2008
    I tried juliegail's method of holding both menuand stop button and it worked for me. Though i lost all my recordings but my stuff is working perfectly. i suggest you try the method because i also use Olympus VN-2100PC
Not sure about what you did SmithJones. I tried juliegail's solution and it worked for me. I suggest you try it again because i also have Olympus VN-2100PC.
Posted on Jun 23, 2008
I had this same problem with my vn 4100 olympus digital recorder. I learn from someone else on this site that you could just hold the display/menu buttton and the stop button at the same time for about 2-3 seconds. the FOR display comes on and all you have to do is wait a couple of minutes and your recorder is working again. Just keep in mind that all previous recorder will no long be there. they will be deleted.
Posted on May 02, 2008
When I connect the vn-4100pc to my computer I get ERREL on the screen. Please let me know how to resolve this.
Check to make sure the O/S of your pc is compatible with recorder.
If you have lost your users manual go to www.olympusamerica.com to download one.
Sep 27, 2010 | Olympus VN-2100PC Digital Voice Recorder
Digital Voice Recorder Vn-3100
are you sure it doesn't say "CLEAR"? Which looks like ERR on the display. Its asking if you want to "clear" all data from the recorder.
Page 9 of your manual. Here's links if you need them:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1272
http://www.olympusamerica.com/files/VN-3100_VN-3100PC_Manuall.pdf
Nov 27, 2007 | Olympus VN-3100PC Digital Voice Recorder
I just removed the batteries of my olympus vn-3100- shows ERR
you should replace your old battories put the new battries in it. carefuly.
Apr 26, 2010 | Olympus VN-3100PC Digital Voice Recorder
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
Voice recorder display err message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Oct 10, 2009 | Olympus VN-3100PC Digital Voice Recorder
Olympus DW90 Digital Voice Recorder - Display Shows CHK and beeps
Make sure the recorder is out of the HOLD position. The HOLD switch is like the on/off button to the device. If you move it out of HOLD the device should come on and you should be able to start recording on it.
Jan 22, 2009 | Olympus DW-90 Digital Voice Recorder
Olympus VN-3100PC Voice Recorder Problem
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Jun 25, 2008 | Olympus VN-240 Digital Voice Recorder
I got a error on my olympus VN-3100PC
yes the above solution ie by pressing "STOP" button and "DISP/MENU" button at a time is solved my problem showing "ERR" in VN 2100PC olympus voice recorder
Jun 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
Error message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
May 26, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-2100PC Digital Voice Recorder Logo
284 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
