Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
ESP-3 printer does not print yellow component. This happened from new and is not affected by changing the ink cartridge.
    Sergeant:
  • 144 Answers
Try to reinstall the printing software once again with the CD provided, if the problem exists call the customer care to sort out.
Thank you.
Posted on May 08, 2010
  • Earl Schlueter Jul 10, 2011
    Replace the print head. Get at Kodak website. $25. I did it, works fine now.
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 printer only printing in blue and yellow
According to your problem first check your printer setup. You may have to change the black ink cartridge. But first clean the head of the printer and align the cartridges.
Jun 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
New kodak esp5250
Try to clean the printhead
Press Home > Maintenance > Clean printhead
If still the same issue
Visit www.kodak.com/go/itg
IF still same issue call or chat with tech support and get the printhead replaced free of charge
Jan 03, 2010 | Kodak ESP 5 Printer
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
Kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 17, 2009 | Kodak ESP 5 Printer
Black and Yellow do not print even with new ink cartridges
no,, it can be like,, you have used those colors prior usages..
Sep 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
316 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
