Question about Maytag MZD2766GES Side by Side Refrigerator
Frig not cooling and now freezer is frosting
My frig side isnt cooling and now the freezer side isnt cold enough to make ice, seems to be cold on bottom and not on top where ice is. I emptied the freezer yesterday and found there was alot of frost on the bottom back wall of the freezer, melted it and as the day went on it seemed to get a little colder. I turned it to mid on the temp which made it not quite as cold but the frig side is only about 60 i am not sure what they should be, yester day it was 72 now the freezer is empty and more frost is building up again. I would appreciate any suggestion you can give. 2 weeks ago the frig was not cold and I found frost in the top by the ice maker and defrosted it and it worked great for about a week. I hope I have been descriptive enough.
Valerie
  • Anonymous Feb 09, 2009
    my fridge not cooling the food, although the digital panel is showing the coldest possible number
  • 725 Answers
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
  • Franklin Ouchida
    Franklin Ouchida Apr 05, 2008
    Good to hear that you got it working But you still hav a defrost problem it will work for about 2 weeks untill the frost builds up again and stops the air flow... temp should be 0 in freezer and 38 in your fresh food side . leave a bowel of full of water to test the temp point the gun directly into the water to get the correct temps.
    parts that may be faulty are
    defrost timer
    ADC (adapative Defrost Control)
    defrost thermostat
    Heater
    if you feel that you can take apart your fridge. and replace the parts. and have the tools screwdrivers/ meters I can help you test and replace the part if not. you will need to call a tech... let me know...Karazytech
Dear Krazytech, I just did what you said and the frig is cooling great and the freezer is freezing! I am so happy, Waht makes this happen? I emptied the resivoir under the frig, It was really full! So do you think it is safe to put things back in the frig? What should the normal temps be for both sides? I have a temp gun LOL that is the only thing I have to use to tell temp. In one hour this morning it started dropping dramitic so it is blowing on the frig side real good. Thanks for your help!
Valerie
Posted on Apr 02, 2008
SOURCE:
Freezer frosting up at ice maker base, and fridge is not getting cold enough. help!
if freezer side is frosting up / the defrost system is or has failed . there should be no frost in a no frost frig . being a G E either the radiant heater has failed of the defrost p c board is out . most common and least costly is the heater .. hopt this helped mm
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Freezer not cold enough, frig ok Frigidaire FRS6LR5EM7
Your defrost element is probably faulty, this is in the freezer compartment at the back and behind a removeable panel. You should change both the element and the defrost limiting thermodisc at the same time.
Mar 03, 2009 | Refrigerators
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
597 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
