Question about Lexmark X5470 All-In-One InkJet Printer
How do i get the ink cartridge out to refill - Lexmark X5470 All-In-One InkJet Printer
    Sergeant:
    Champion:
  • 236 Answers
The website will guide you through
Posted on May 08, 2010
Refilled ink cartrige still showing empty is their any way to reset printer
Regarding your HP Officjet Pro 8600 printer and refilled HP 950/951 ink cartridges and the "low ink" messages. Depending on your ink refiller (or if you did it yourself?), a replacement chip may or may not have been installed with the recently refilled cartridge(s). Refer to picture on our support site to first determine which type of cartridge configuration you have, then refer to the applicable section to address the current cartridge error(s) or printer issues.
http://inkjet411.com/?page_id=1999
NOTE: Costco USA's Ink Refill service now 'chips' all refilled ink cartridges which fully restores all functions to that of a regular HP (OEM) ink cartridge and customer experience. For USA ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
Refer to Section A if your refiller attached a new replacement chip (green in color) onto the cartridge. Refer to Section B if only the original HP chip is attached.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations). We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested! HP original/genuine ink cartridges can be identified by the visible HP logo on the front label of the cartridge.
HP 950/951 Ink Refilling & Additional Cautions:
http://www.youtube.com/watch?v=zOCC3h0OFiI
Questions regarding the use of refilled ink cartridges: http://www.inkjet411.com
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Mar 31, 2014 | HP Hewlett Packard Officejet Pro 8600...
Can you refill dell series 21 ink cartridges?
Any ink or toner cartridge is refillable, For ink cartridge, check for the small pin hole at the top of the cartridge to inject the ink refill. But remember that the ink should be compatible with your ink cartridge model. Good luck
Jan 05, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
