Question about Maytag EPIC MFW9700S Front Load Washer
Cold water wont stop running during all cycles and after the machine shuts off it fills with water
  • Maytag Master
  • 12,061 Answers
Http://www.maytag.com/content.jsp?name=troubleshoot_washers_neptune
http://www.servicematters.com/maytag_library/docs/16007803.pdf
http://www.washerhelp.co.uk/diy-repair-help.html
the links above are for, DIY washer help, great help, the next, is a service manual for troubleshooting and repairing, the top link, is the official support site it's very good.
If you think, you cannot sort it out, or you simply don't want to take any chances, contact a Matag and ask for a serviceman and get a "Quote" for the repair, simply explain it as you see it.
Ok, this is a fairly common one, what is happening is the Cold Water solinoid, either isn't being commanded to shut off, or the solenoid is faulty, or it is jammed open, sometimes sediment builds up and hold them open, you will have to troubleshoot to find out, I have given you some links to service and repair manuals, you should be able to pinpoint your problem and hopefully effect a repair.
Try unplugging it, if it still fills, the solenoid valve is stuck open. If it stops, it could still be the solenoid or the control pane
Posted on May 08, 2010
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Dec 31, 2008 | Washing Machines
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
COLD WATER DOESNT SHUT OFF AND SPIN CYCLE STARTS AND STOPS
The pressure tube switch tubing gets clogged on these machines. The best way to repair is remove the 4 torx screws securing the control panel, On the water level switch remove clear tube from switch, with some water in tub, i suck water up and back down the tube, clearing the tube. After tube is clear spin machine for 3 mins. Test water fill again.
Dec 04, 2007 | Washing Machines
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
