Question about Marantz Reference TT-15S1 Turntable
Marantz TT221 turntable anti-skating problem
Pulled my turntable out of storage (8 years+-) and now the ant-skating is pulling hard enough on the arm that clicking the cue sends the arm to mid record. I have turned down the anti-skating and that gets me mid record, in its normal setting it goes straight to the middle of record.
Is there a procedure for opening them up and adjusting the tension on the anti-skating down?
    Champion:
  • 271 Answers
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Posted on Sep 15, 2010
  • 33 Answers
Hi, take a WD40 spray it gently on the part of the mechanism..
Posted on Jul 09, 2009
3 Suggested Answers
technical114
  • 1851 Answers
SOURCE: I can't get my Marantz 6025 turntable to turn?
As you Marantz 6025 is a belt drive type turntable, the most possible problem is that the belt has been cut or destroyed. You can check it out before order a new one.
Here is the replacement procedure. Pull up the rubber mat, pull up the platter and find the belt. If the belt is removed from the platter, replace it with the glossy side outward. Pull the platter back at the original position. Turn until one of the 2 big openings come over the motor pulley. With your finger place the belt from the platter at the motor pulley. Pull the rubber mat back. You are ready. Here is a schematic for all the above:
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 13, 2010
SOURCE: My Marantz 6110 will not shut off-turntable keeps
My Marantz 6110 wasn't working right. I had it repaired at a stereo store. They told me the grease was old and had hardened which made it difficult to operate the way it was supposed to. They cleaned it and used new grease. It's been working great for the last 10 years. I hope this helps.
Posted on Jan 10, 2011
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Dec 11, 2014 | Technics Audio Players & Recorders
Needle skipping towards end of record
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 28, 2012 | Stanton STR8-100 Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Specs for Technic Sl1210M5G Turntable
Anti skate should be set the same as the weight, i.e 3 gram of weight = 3 on the anti skate.
http://stores.ebay.co.uk/methleykev
May 19, 2010 | Technics SL-1210 Turntable
Stylus skates across record; doesn't engage grooves
Increase the weight of the arm, check if it has anti-skate control.
Dec 30, 2009 | Audio Players & Recorders
How do I adjust the anti skid?
Perhaps it might help to know your symptom . There are no user adjustments for either tracking force or ant-skate. They recommend making sure the TT is level.
Nov 20, 2009 | Sony PS-LX350H Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Marantz Reference TT-15S1 Turntable Logo
1,445 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
