Hi I have a simpson Delta 402 washing machine and it wont drain? I have manually drained it and checked to see if it is blocked at all, and tried to put it only on the drain cycle but nothing works, any ideas?
  • stickifrog May 09, 2010
    Thank-you I will give it a go.
  • luisa_sgro May 11, 2010
    sounds like your pump is jammed or faulty. have you got the drip/dry option on your unit? it should be at normal setting. now, the pump is located at the back left of the unit where the drain hose is attached. has your machine got a back panel that you can remove so you can see the pump? if it has please reply and i can guide u thru fixing this problem. 80% of the time i have found the pump jams.please turn power off b4 you work on it.
  • Washing Mach... Master
  • 713 Answers
If u can see the pump has it got a fan attached to it? it should b white or black. if has got a fan try turning it to loosen the object jamming it. if it is firm to turn and it doesnt get loose then u may have to strip the pump.if it has no fan then your pump is a syncro type. please reply with additional information 4 more help.
Posted on May 10, 2010
Back panel is off. drip dry setting is off.
machine fills, but doesn't drain even after a spin.
I can see the pump, how do I turn it to see how to unjam it?
Posted on May 09, 2010
  •  adrian price
    adrian price May 13, 2010
    problem solved, your heads up about the pump allowed me to figure it all out: 4 hair pins from kids clothes jammed in the pump. Once they were gone it's all back to normal
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
I have a simpson washing machine that doesnt drain after wash what could be wrong
water pump or water pump solenoid
if they check out ..faulty timer
to drain water out
have to put the drain hose on the ground out the door
or towels and buckets
Sep 17, 2016 | Simpson Esprit 750 Top Load 7.5kg
My simpson esprit does everything ok, but it wont drain out, had to put the hose on ground to drain, but when i l lift hose up to drain, it dont drain what to do
Sounds like your pump is not operating. Possibly a broken belt and needs replacing. or pump seized up. Check belt first.
May 12, 2015 | Simpson Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Hi My Simpson EZI set 7.5kg washing machine has an error 'Ed' and it wont go
That means it is having issues draining. PLease check the filter on the pump and make sure that the drain hose is ok.
Aug 31, 2013 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson delta 402, I need to remove agitator, how please?
It is a nut on top of agitator you need a special tool
Jul 11, 2011 | Washing Machines
What is the weight capacity of a Simpson Delta 402 Washing Machine?
The information should be on the manufacturer's plate on the back of the machine and in the manual. If you no longer have the manual you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You can also try the manufacturer's web site direct ;-0)
Good luck,
John C.
Apr 06, 2011 | Washing Machines
I have a simpson front load washing machine and it is not draining?
apart from having a faulty water pump check to see if you have a blockage maybe filter is blocked or something caught in drain hose alternatively you might have a control or wiring problem let me know how you went
Nov 12, 2009 | Washing Machines
Simpson eziset 450
It sounds like the drum is so away from level that water is not flowing to the drain line, hence the pump running out of water. I would make sure the machine is level and the drum is resting level if it's the type that pivots around inside the machine. Failing that I would open up the machine and check the hoses to make sure they're not blocked. I would also check the drain hose to make sure it's not placed too high or in a way that will obstruct water flow.
Oct 19, 2009 | Washing Machines
Washing Machines Logo
501 people viewed this question
Top Washing Machines Experts
