Question about Belkin (F5D5231-4) Router
Installation of belkin router failed
Trying to install belkin gouter g onto windows xp, my window media player cannot play the file on the install cd as computer does not support that type of file od I need a codec
  • 4,281 Answers
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 08, 2010
Microsoft says windows media player should play .wav files but my XP desktop will not - ?
go to VLC mediaplayer.com download & install it, its a better media player and plays many different formats then windows media player
Sep 21, 2017 | Microsoft Computers & Internet
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How do I install Windows Media Player 11 on my Windows XP SP3 Dell Inspiron 6000
Try Re-Installation, if it persist restore Factory Settings then RE-Install but if all this fails take it to a cafe near you LOG onto the Dell office you'll be able to solve it there.
Nov 16, 2009 | Dell Inspiron 6000 Notebook
Windows media player won't play DVDs
this problem is due to the decoder is missing in media player. you can download and install decoder from here
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx#DVDDecoder
just install it and play the DVD in WMP.
Question : Is your laptop is DELL???
Sep 03, 2009 | Microsoft Windows XP Professional
Cant get past cd installation
Grab the software from Sandisk's website and try again. If that fails, upgrade your XP to SP2 or 3.
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
Windows media player not working
Very the file you are trying to play is still there , if it is then create a new play list by allowing WMP to scan your system for playable media. If this fails or the above aint the latter then i'd suggest you uninstall WMP and reinstall it. WMP is in the control panel / add or remove components / Windows Components. You can also log in to microsoft web site and download the latese WMP and install it .
Jul 09, 2008 | Microsoft Windows XP Home Edition
Sound Divice
an1978an
to ensure that sound driver is installed or not right click on "my computer" go to "properties" then click on "hardware" tab then click on "device manager" then chack any yellow question mark(?) or exclamation (!) mark is their or not if (?) marks show with ur audio device, mean audio driver not installed. installed it from mother board cd (which is provided by ur motherboard vander).
Jun 25, 2008 | ASUS P5PE-VM Motherboard
Can't open downloaded files off Media Player 11 off new pc with Vista installed.
Try administrator rights by right-clicking on Windows media player or try to turn off UAC(User acc control)
May 20, 2008 | Insignia NS-DV2G MP3 Player
My memorex mmp8640 wont let me add videos!
There should have been a mini-CD that came with the item, that contains the software you need to convert the video.
Apr 12, 2008 | Memorex MMP8565 MP3 Player
DvD Player on PC
try and install decoder from updates of windows media player,and search for windows xp decoder ,and update ur windows
Mar 15, 2008 | Computers & Internet
Belkin (F5D5231-4) Router Logo
237 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
