Question about Moulinex DAE24 2Speed Blender
Glass hard to clean
How to clean glass container
    Brigadier General:
  • 4,090 Answers
Fill with water and place a tablespoon of bicarbonate of soda in it and leave for 1 hour Then scrub with ploymit and rinse
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Does the white plastic base bottom of the glass blender come off for cleaning or is it attached permanently
Yes the white plastic base comes off. There are several model of the BL10450; here are the Instructions which contains an illustration of the assembly:
https://www.unitycart.com/pjss/parts/parts_classic.asp
See the notes on Blender Jar Assembly. It turns on clockwise; off would be counter clockwise.
Mar 07, 2011 | Black & Decker BL10450 10 Speed Blender
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
Leaking from the bottom of the glass container through the screw
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
Nov 08, 2009 | Oster 4093-8 Osterizer Classic Blender...
The handle to the pour spout on the bottom of the blender has broken off. So I can not put smoothee in my glass. I have to pour it in my glass for the top of cannister. Where can I get replacement parts?
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have the smoothee spout. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Oct 16, 2009 | VillaWare 5785 Smoothee Bar Work Top...
I'm having a hard time disassembling my Kitchen Aid blender. Does the container come apart from the screw on the underside, detaching the plastic from the glass?
Have a look at the instructions here:
http://kitchenaidblenders.co.uk/KitchenAidBlenderGlassJugJarDisassembly/tabid/157/Default.aspx
This is for the glass jar which may be slightlt different.
Oct 02, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Moulinex DAE24 2Speed Blender Logo
81 people viewed this question
Top Moulinex Blenders Experts
eyecam
Ross Keen
Are you a Moulinex Blender Expert? Answer questions, earn points and help others
