Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Fisher&paykel dishwasher wont work says F1 - Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
  • Fisher and P... Master
  • 12,061 Answers
The f1 fault is cased by a leak on the dishwasher.
It is activated when water gets to a dangerous level in the base of the appliance near to the PCB.
The main reason this happens is putting cups on the drop down shelves and when the lid comes down to seal the drawer it can't and leaks. If you look at the drawer when open there is a lip around it, if anything is proud of this lip the lid will not shut properly.
To rectify this problem you will have to disconnect the power and remove the bottom drawer and the dry up all the water in the base. If you leave the appliance long enough it will dry out by itself.
Once you have done this and the problem still comes back you will need and engineer as there is a problem with the lid motors or the seal’s.
Posted on May 08, 2010
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error code continuosly
here is a link to a downloadable repair video. This video explains how to repair a f1 error code and how to replace the rotor.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Mar 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher dial flashing F1
the flood switch at the base of the dishwasher cabinet has activated. This occurs if moisture has leaked into the base of the dishwasher.
There are several posts on the fixya.com site on causes and solutions.
If unable to find please post a comment and I am happy to guide you on this.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Fi code washer wont stop beeping
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
May 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
139 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
