Question about Jeep Cherokee Sport Disc-Brake Mountain Bike
The gear handle seems to be ceased. can i take it apart and put some oil on it
    Sergeant:
  • 144 Answers
Simply filling oil will not be a solution because if it is some other part you can do it, but it is a gear part you have to be careful.
You better call the technician to solve the issue.
Thank you
Posted on May 08, 2010
My gears on my kia sportage 1997 ceases up after a short drive.
1 make shore you have the correct grade AUTO transmission oil.2 fit an external oil cooler. This can be done two ways. no1 add it into the system by cutting the oil return hose from radiator to the gear box and install the cooler or. no2 completely disconnect the radiator and install the external cooler independently.either way you will need oil cooler 2 lengths of transmission hose & 4 hose clamps. In Australia it comes as a kit with all clamps & hoses cost depends on size small medium or large cooler. when fitting I found it best to cut the pipes in the space between the radiator & the motor gives you more room to work just have to use longer bits of hose. Hope this helps. sick51
Feb 18, 2013 | 1997 Kia Sportage
Subaru legacy 1997 shudders when accelerating through changing gears car is automatic
if this happens while the engine is cold please run it idle once to start in the morning then drive and if it does always then. put the gear to neutral with the brakes on and push the accelerator slowly to higher side to see if engine is smooth if it shakes or shudders or engine seems to un stable use carburettor cleaner with the engine roaring say around 2000-2500 rpm. just spray from the opening intake of the air filter on top of the engine. spray two to three times, if it does not work remove the top cover of air filter remove the air filter and close the cover then try again. if it still does not help take the car to service station to check for all hydraulic oil and clutch oil. are you sure that engine oil is on top indicator or it is low. this could also be the reason and the engine could cease also.better first check for the engine oil level on the oil dipstick.usually located near the fan belts of the engine front side
Aug 29, 2012 | 1997 Subaru Legacy
Ii was riding it earlier and i shut it off then when i got back on it a went to kick it and the kicker was stuck it wouldnt kick. what could it be
The most common causes for this are a ceased piston (for instance, if there was an oil failure, the bike probably wouldn't have ceased until it was turned off) or if an internal bolt has gotten into the bottom end somewhere jamming the crank or kick mechanism itself.
Try removing the cylinders first, as that is the most likely cause of the failure.
If the piston is stuck in the cylinder, you may need to put a block of wood onto the piston and gently tap it out of the cylinder to effect repairs on the bike.
If the pistons come out of the cylinders without sticking, then having the cylinders removed will let you get a look into the crank area for loose bolts etc.
Don't forget to tie off the cam chain so it doesn't fall into the crank, because that's a pain to fish back out.
If you can't see anything wrong in the crank area, you will likely have to open up the bottom end to see what has gone wrong.
I wish I could be more help, but you didn't specify which bike you have.
If it's a 2 stroke, chances are the gas/oil mix was off or it ran out of 2 stroke oil and the piston ceased.
Mar 25, 2011 | kawasaki KX 250 F Motorcycles
After heater is on for awhile it seems to cause smoke in the room and the bottom of the heater has turned tan.
This is quite common, the oil has seeped out of a cracked seam, this then gets heated up by the heater and smokes, a bit. although probably not too dangerous, i advise you cease using it. There is no real cheap way to repair these leaks, apart from welding the seam again.
May 19, 2010 | Lakewood Oil-Filled Electric Radiator...
I have a toyota corolla 2001 and I am wondering if a P17570r14 would have a smoother ride than a p17565r14?
the 70 has a higher aspect ratio so it will ride smoother becasue it is taller between the wheel and the ground.
Oct 07, 2009 | 2001 Toyota Corolla
The inside and outside door handles will not work on my wifes 1999 honda accord. The lock works but i cannot get the door to open. it feels like the handle isnt catching on anything.
latches are siezed and will require so help to open. try using a rubber mallet and tapping the outside door handle till it seems to have some resistance. you might have to tap alot. once the latch spring is in the right place then lock and unlock car to activate the clips and then pull handle. repeat untill door opens, then take door apart, remove latch and oil till all clips and spring move freely. Now put it all back together and it should work well.
Sep 05, 2009 | 1992 Honda Accord
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Engine ceased VW 2004 passat 4cyl. 59k, multiply oil changes from local garage, VW too expensive engine ceased. called VW they want to change me to see the car. What shoud lI do?
Let them see the car.
Did you check to see if the vehicle actually had oil in it? Sometimes small shops forget to put oil in or forget to put the oil plug back on.
It may be less expensive to go to your local corner garage at first, but now look at what it is going to cost you.
You may be able to find this engine in the scrap or junkyard. Look for a car that has rear end damage. This indicates that the engine is still good and none of the seals have been shifted because of the damage. Front end damage may cause seals to shift and have an oil leak
Jun 29, 2009 | 2004 Volkswagen Passat
Car ceases to accelerate after about 15 to 20 minutes drive.
when it reaches its top speed of about 15 to 20 mph does it rev out or does it stay in that gear?
Dec 04, 2008 | 2003 Toyota RAV4
Jeep Cherokee Sport Disc-Brake Mountain Bike  Logo
Top Jeep Cycling Experts
Lawrence Oravetz
Jerry Kramer
Jerry Kramer
Bill Boyd
Are you a Jeep Cycling Expert? Answer questions, earn points and help others
