Question about DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture
Hi i own a easycap and i get a green line at top and a funny line at bottom can someone olz help me to set this right cheers
Which fuel hose go to the top of the carb and which to the bottom? Which lines from the prime bulb go where? Replacing the bulb and all fuel lines.
Hi ibcasady...
The bottom fuel tank line runs to the bottom connection, the top fuel tank line runs to the top...
Test it to make sure that is the right direction, and that the carburetor is being primed with fuel...if not reverse the hoses.
Free Answer...Please take time to rate me
Jun 05, 2011 | Ryobi Garden
The vertical green convergence adjustment is broken
Either your convergence ic's are bad or the convergence digital module ( if your model has one ) . I would have it looked at by a service company.
Jan 16, 2010 | Hitachi Televison & Video
Change extension to another line pool
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the show key (top right arrow)
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
The display should say Prime Line
Press the Chng soft key till you get to the desired pool
Press the release key when finished
Oct 01, 2009 | NorStar Meridian M7310 Phone
I replaced the fwd / rev switch on my Club Car 1985
I recently replaced a F/R switch and just happened to write down which wires went where so maybe I can help. The front switch ( closest to front of cart) green/white wire to top contact, white/black to bottom.
Middle switch red/white to top, orange to bottom.
Rear switch green to top, black to middle and white to bottom.
Jul 27, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Flashing bottom screen (Nintendo DS Lite)
You need to check the top screen ribbon is fully inserted into to place on the board. A green light and flash of the screen within a second means ribbon not connecting right
Jun 05, 2009 | Nintendo DS Lite
I have a Panasonic TH-50PZ700U, with a green 2'' vertical line in the upper right hand corner. The green line is there regardless of input and is constant. Around the line can have lighter lines at times...
It is the buffer X board. They are loacted at the botton of the set. Replace the one connected to the display panel directly in line with the lines in your picture.
May 08, 2009 | Panasonic Televison & Video
Ulead 11 with EasyCap on Windows Vista
souds like you have not selected the correct video type - try all the diff Pal ones
Apr 08, 2009 | Televison & Video
Fridge running light(green)flickering
hi,thanks for your e-mail i couldn't find a solution and the fridge was fairly old we bought a new one,cheers,vic.
Nov 30, 2008 | Candy CPCA240FFK Bottom Freezer...
Funny coloured screen when i turn on the camera
did someone find the solution ; let me know.. best regards theodore
notodoras@yahoo.gr
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture Logo
460 people viewed this question
Top DekCell Televison & Video Experts
Robin Hill
Robin Hill
ka4iup
ka4iup
Clif Roberts
Are you a DekCell Televison and Video Expert? Answer questions, earn points and help others
