Question about D-Link Xtreme N DIR-655 Wireless Router
SharePort Utility will not detect iosafe solo external hard drive
I am operating on windows xp PRO with a D-Link DIR-655 router (Firmware Version: 1.21) and I have installed the the latest SharePort utitity (version 3.0.0 R1).
I am trying to connect my iosafe solo 1.5 TB external HD to my router via USB either through my computer or the USB port on the back of the router. The problem I am having is that the SharePort Utility simply cannot detect my hard drive. I have added it and SXUPTP to my list of exception for Windows firewall. I have configured my external hard drive for file sharing by right clicking on the drive icon and manually selecting the settings through sharing and security.I have tried using a different USB cord. I have also tried uninstalling/reinstalling the SharePort Utility
I am not sure if the problem lies with the SharePort Utility or with the iosafe freeware. I read quite a few blogs and support forums and i seem to be the only one having this problem that i know of. I do not have another external hard drive to test unfortunately.
mastersaintx
  • 928 Answers
SOURCE: Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Posted on Jul 27, 2008
beeveez
  • 167 Answers
SOURCE: My DIR 655 is able to conect to my laptop through wireless
Do you see wireless signal of your router from your Laptop? If not! make sure the Wi-Fi of your Laptop is activated for you to get online wirelessly.
Posted on Mar 08, 2009
beeveez
  • 167 Answers
SOURCE: Will a D-Link DIR-655 accept a usb data card?
- They're both function as an USB and Air Card.
Posted on Mar 17, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
SOURCE: My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Posted on Jul 21, 2009
There is no wireless internet conection from the router to the network places
make sure you turned on the wireless adapter....Check for the driver status....go to start>run>type "services.msc"
scroll down to wireless zero configuration (for xp) / wlan auto config (vista and win 7) and start the service....
also disable any utility that controls your wireless adapter and use windows default utility....
Mar 29, 2010 | D-Link DIR-655 Wireless Router
We just bought a new emachine, Acer E627, with windows 7. I cannot connect it to our home network using a D-Link DIR-655 router. It has always worked fine. Other computers can connect to OUR network, we...
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Feb 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a D-Link DIR-825. I bought it brand new.
Don't you have to "Bridge" connections between the USB & Ethernet? In the routers setup?
Feb 06, 2010 | Computers & Internet
I need updates for dir 655 for windows 7
The only real update is a firmware upgrade. I'm having constant disconnect problems and the firmware upgrade only made it worse. Either wait for a better fix from D-Link or return for a different router. Updates and other information can be found here at D-Link's support page http://www.dlink.com/products/?pid=DIR-655&tab=3
Dec 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How do i add the printer the dlink dir 628 router
The DIR-628 does support a USB printer. You need to download the appropriate shareport version from dlink http://www.dlink.ca/products/?pid=DIR-628&tab=3.firmware
If the printer drivers are already installed on your PC you should be ready to go.
Sep 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DIR-655 wireless intermittment - connections drop -
Any one with a mac ... MAKE SURE "Enable Auto Channel Scan : " is OFF.
CHANGE the name of the WIFI Network.
SET the Channel to CH11 [Others interfere with phone signals]
SET Security to WPA, TKIP Cypher, 3600. Then enter your password [min 8 all lowercase chrs] Change it when you are working.
Save and unplug the router and you will be fine.
Feb 08, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DIR 615 affecting playback of music files on Windows XP
You have to be on a wired connection to upgrade your router. Wirelss connections will not be allowed for firmware upgrades to your router.
Jan 28, 2009 | Linksys Wireless-G WRT54G Router
Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
736 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
