Question about Sony Playstation 3 (PS3) Console
Ps3 not connecting to tv, all cables in the right place, was working fine for 3 years until now! usual set up not working so have tried all others but can't get the ps3 to work on any channel
  • sinead_turnb May 12, 2010
    thank you for your help unfortunately this didn't work; the ps3 unit seems to power up but can't get any display on the tv
  • Sony Expert
  • 311 Answers
Does the ps3 power up and seem to work as normal?
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
Posted on May 08, 2010
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
My playstation 3 was working fine, im now trying it on another tv and it wont work. i have tried all the reseting display settings by putting the console on standby and holding down the power button until...
Please check the cables used to connect the ps3 to the tv screen. whether it has been copatible or may experience constraints to connect. Replace immediately if the cable is not good. ps3 section for setting the output to a tv. hopefully help.
Aug 02, 2011 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
AV Cable Problems
try turning your tv on the input that you have the ps3 plugged in. Then with your ps3 on standby (the red light is on), hold the power button until the second beep. This resets the video settings
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Trying to connect playstation 3 to my tv having no success
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Feb 17, 2008 | JVC LT-37X776 37 in. LCD HDTV
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
137 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
