Question about Sony CMT-CP11 CD Shelf System
I have problem with my sony cmt-cp1 model. NO DISC
I have problem with my sony cmt-cp1 model. when i put disc in tray he start o play about tree seconds and then on display write ''NO DISC''
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
My cd player does not play music in order, instead of 123...it skips to 5 than 8 etc.
There's a control under PLAY MODE that selects random play labeled "1 DISC SHUF". Normal play would be "ALBM". Read the manual.
http://www.retrevo.com/support/Sony-CMT-HPX9-manual/id/268dj180/t/2/
Jul 18, 2011 | Sony CMT-HPX9 CD Shelf System
I have got a Sony CMT-EX100 Micro System. When I touch the OPEN/CLOSE-button on the top, the system doesn't open. I opened the system and it seems that the magnetic disc-holder holds the disc-tray too...
This problem is easily repaired! The belt that drives the mechanism is worn out (relaxed) and slides on the motor pulley. Just open the device (from the bottom and then drag the body up by removing the edges). You have to put a new belt section ø 35 mm 1 mm and the unit will work again.
(hello from France)
Jun 05, 2011 | Sony CMT-EX100 CD Shelf System
Sony CMT-EP515 CD Shelf System. CDs wont play. Place CD in tray and close, disc doesnt spin but 4 distinct clicks heard then nothing
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
Aug 04, 2010 | Sony CMT-EP515 CD Shelf System
How to play movie dvd in playstation 2 ?
open dvd case.
take out disc.
place disc on ps2 disc tray.
put disc tray into console.
enjoy.
Jul 08, 2010 | Sony PlayStation 2 (PS2) Console
Micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Sep 16, 2007 | Sony CMT-BX1 Shelf System
Sony CMT-CP11 CD Shelf System Logo
893 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
