Question about Amana ACS3350AS Gas Kitchen Range
Apparently, the range works fine but the oven fails to fire; my friends son in law has this problem and I have been asked to discover why.....I am believing that the ignitor is the possible problem, any input, thanx
    President:
  • 1,015 Answers
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
Posted on May 08, 2010
Whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Can you please tell me if you have replaced the thermostat?If not then please do that.
Waiting for your reply.
Feb 24, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
Why did my maytag gemini double oven coil caught on fire and break in half?
Because it failed
Ask an appliance parts store how
many times they see that
Jul 18, 2014 | Maytag Gemini 30" Self-Cleaning...
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
Oven won't get up to temperature
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 14, 2010 | Frigidaire Gallery 30" Self-Cleaning...
LCD not working on microwave
The is a prone problem accross the Sharp range where the LCD fails. They can be repaired but this can be quite costly.
Feb 17, 2010 | Sharp R-370E 1000 Watts Microwave Oven
Fire in the oven in self cleaning mode
I would let the oven cool down then unplug the range from the power for at least 10 minutes. Then plug the range back in and see if the error goes away and the oven unlocks. Hopefully this re-sets the system. If the error does not go away then there might be a fusable link in the broiler/burner compartment that has melted due to the fire as a safety feature. If that is the case then a new fusable link might need to be installed to get the range working again. The reason for this is because there might have been electrical wiring or other components that were damaged from the fire.
Jan 18, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven fire
sure it will . just clean it up good . mm
Dec 24, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Kgrc707 oven not working
it may hav over heated and caused the one time safty on back of oven to trip . replace safty and it should work . ps some times if it has a cooling fan the fan may have quit causing this problem . when the saftey failes look for the cause .. it will do it again . and the safty is about 30 .00 .. mm
Dec 24, 2009 | KitchenAid KGRC707 Stainless Steel Gas...
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
402 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
