Black screen, no picture, sound = yes
Philips 42PFL9632D10
  • 12,061 Answers
Http://www.scribd.com/doc/26366292/Philips-q528e-Service-Training-Manual-Part2
use this training service manual to troubleshoot and isolate the problem. So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else
Posted on May 08, 2010
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
How do I fix a black screen with sound working and LED light on.
Unplug the set and let it stand for two minutes. Plug it back in and see if it works. If that doesn't work contact Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 14, 2015 | Philips 42PFL3704D LCD TV
Tik tik sund from philips tv
when i turn on my philips 20 in flat tv i have no picture, just black screen with a tik tik sound
May 11, 2010 | Philips Magnavox 27MS343S 27" TV
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Jul 31, 2009 | Philips Magnavox TS3260C 32" TV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
729 people viewed this question
Top Televison & Video Experts
Electro Med Services...
