Question about LG LFN300CP Split System Air Conditioner
Not geting cool
We are renting a flat with this air con system and no directions, how do we set it to cool down, the fan works the plasma screen works but we can not get cooler than 27
    President:
  • 1,515 Answers
Hi, I'm not sure how to tell you about the remote for this unit, but if it is on cool and you have lowered the temperature with no luck, You need to start it and go outside to the outdoor section to see if the fan is on, and you should be able to get down by the control panel and listen to see if the compressor is running. If you get out there and it is off, you have lost power to this condenser for some reason. Check main breaker to see if tripped. There will be an electrical box mounted there also. It will have 2-fuses inside. If breaker is on and its not running, pull the plug in box. If you cant see fuses, they will be behind the plastic cover. Change them both. This is only if it is off. You have a coil on this unit that may be very dirty. Shut off power to it and take a water hose to wash the coil very good to remove all dirt. Be careful not to bend the aluminum fins on coil with to much pressure. Try all of these solutions and let me know. You may be low on freon also, but we will go there after you have checked the above. Get back to me soon. Good Luck,
Sincerely,
Shastalaker7
Posted on May 08, 2010
I have a Rover 75is it normal for my engine fan to come on high when i turn on my airconditioner
typical set up is two fans in engine bay
engine cooling fan is separate
air con fan runs flat out when air con is on to cool condenser
Apr 28, 2017 | Rover Cars & Trucks
Samsung plasma tv white screen repair
You have a shorted main board in the TV, it is more expensive to repair this than to replace the TV at current TV flat screen prices. Also I suggest the brand Vizio, it has the bet reliability ratings of any brand hands down.
Aug 11, 2016 | Samsung 50 in. Plasma TV
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
My computer overheats and shuts down. The more programmes you use the quicker it shuts down. So fed up and Acer want a fortune to fix it. can i fix it myself.
Yes - take apart the CPU fan. Underneath is the CPU. Remove the old heat compound (silicone) and re-apply new compound. Don't forget to clean the fan assembly and heat fin radiator - it'll have lots of dust and dirt. Here are some pictures: http://www.facebook.com/album.php?id=104583522919354&aid=7377
Feb 14, 2011 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
WHY DOES MY RADIATOR FAN COMES ON ONLY WHEN MY AC IS ON ON MY 88 TOYOTA COROLLA
it is generally because the air con heat exchanger has to be cooled in order for your air con to work correctly and cool the interior of your car.
The air conditioning utilises a gas by the name of freon. This gas is pumped around the air con system by a compressor. The gas, going through the aircon cooler or heat exchanger, starts to cool down. Depending on the system layout, the gas is forced through a very small aperture situated after the cooler. It reverts to a liquid, passes through the matrix in the car, a fan blows the interior air of the car through the matrix. The fluid picks up the heat, and cooler air exits the matrix and, (hopefully) cools the interior of the car. This endless cycle is repeated as long as the air con is powered on.
Hope this brief description will suffice.
Jan 25, 2011 | 1988 Toyota Corolla 4 Door
My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Jan 21, 2009 | Heating & Cooling
Failure during operation
No. The fan setting simply runs the fan full time bypassing the thermostat. In cooling mode the unit is slave to the thermostatic sensor located in the return air stream. If the unit is in a very small room or the exiting cool air is obstructed by furniture or curtains then the cool air is directed directly back to the sensor before mixing with the room air, causing erratic operation. Be sure several square feet of floor space is open in front of the unit and point the vent upwards and see if that makes a difference. Hope this was somewhat helpful, GL.
Jun 11, 2008 | Panasonic Room Air Conditioner CWXC104HU
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
LG LFN300CP Split System Air Conditioner Logo
47 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
