Question about InFocus SC-MANGRY-106H MANUAL PULL DOWN
Philips 32pt television screen format off center, to the left
Our Philips flat screen 32 inch HD tv is off center. It has "shifted" to the left. Picture is good, but if words are in the left of the screen you cant read the first couple of letters. I have adjusted screen size to 4:3 (it is not on expanded) but there is still about 2 inches of black on the right side and the left is way left.....dont know how or why this has happened. cant seem to get it back to center?
  • 4 Answers
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Posted on Oct 03, 2008
SOURCE:
My philips 32in flat screen tv has no sound
Check its speaker first. If it is found OK, check and replace the audio output card. Contact the authorized service center for Philips to buy a genuine card. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Philips 32PF5320 32 in. HD-Ready LCD...
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Screen Shift PLZ HELP
burn in run  a white screen
Jun 06, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Philips flat sreen t.v. question
It is not normal. Try pressing the FORMAT button on the Philips remote. If the problem still persists, try pressing the Zoom or View button on your cable or satellite remote. If neither resolves your issue, there may be a problem with the LCD screen - call Philips and get in contact with an Authorized Service Center.
-Tha Mp3 Doctor
Feb 17, 2009 | Philips GoGear HDD1830 MP3 Player
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Help
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
The whole screen is shifted 1 inch to the left.
When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
Sep 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
961 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
