Question about Acer Aspire 5500 5570-2609 Laptop
USB Port Problem
The mouse on my laptop stopped working (I have trouble using the touch pad). I think the mouse issue is a problem with the USB ports -- it does not work in either port (I tried a brand new mouse which doesn't work either. At the time this startted I was experiencing random shut downs, which seem to have stopped. I have not added any software. The only thing that changed was I moved offices and plugged the laptod into a surge protector rather than right into the wall socket, which i had been doing. Also, I plugged the ethernet cable for hte T1 connection into a router rather inte the wall which I had been doing as well. I'm stumped. Any ideas/thoughts would be appreciated. after i installed microsoft office, i can move the arrow with the touch pad but i cant click on with the touch pad
    Scholar:
  • 67 Answers
Did something happen to the port setting? To find out, right click on My Computer, select properties, then select Device Manager. Does the Universal Serial Bus controller show up with no X's? Did it show up under the ? Other Devices section? You may need to uninstall and then reboot. Windows will discover new hardware and should find the driver for you.
That's my thoughts, so far. Except for the random shutdown. I am reminded of a guy who brought his system in with USB problems, no Internet, and a host of other problems. I discovered that almost all of his services had been disabled. Services and Applications, Services, also under Manage. I put my laptop on the same screen and restored his settings to match mine. Good luck in your hunt.
Posted on Mar 27, 2008
SOURCE:
My wipro BM49XX touch pad is not working how to solve
If the touch pad is not working I would recommend buying a mouse that can be connected via a usb port. Mouses of this sort can be found as cheap as 1$
Nov 05, 2013 | Computers & Internet
Several times each day my mouse on my laptop (Dell Lattitude E5510) becomes unresponsive. I can then use the touch pad to restore my control or the mouse works if I switch USB ports. It doesn't se
Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Mar 01, 2012 | Computers & Internet
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
My Dell N4010 Laptop with Windows 7 software indicated a message of "touchpad disabled", and I can not manipulate the mouse.
You are confused. Your touch pad is disabled, but if you plug a mouse into the USB port, your PC will find it and install its software and you will be able to use the mouse To re-enable the touch pad, click on the Windows ball at lower left of desktop, Control Panel, Mouse, Touch Pad, Enable Touch Pad.
Oct 18, 2010 | Computers & Internet
My asus K40 series laptop all of a sudden lost the touch pad (mouse pad). I have to use the external mouse through the USB port....can anyone assist please?
seems you need to replace the touch pad, if you have warranty on it return it and have them replace the touch pad
Sep 27, 2010 | ASUS Computers & Internet
Touch pad dosen't work
because your mouse pad is defective, I had same problem, I have no problem ever since I purchased a wireless mouse
Jul 30, 2010 | Acer Aspire 5315 Notebook
Mouse pad isnt working??? I just got my ASUS laptop today NEW. when I boot it up mouse touch pad won't move cursor to log in ect.
r u in DOS mode ? mouse wont work in DOS mode..
if u got the Win Logon screen and mouse does nto work....
Shutdown the machine....
and send it back for a full refund or replacemnet....
u say it's new....so dont fiddle with it...
if u have an external USB/PS2 mouse u can connect it to the USB port or the PS2 keyboard/mouse port and check if the machine is working....
i suggest u send it back or take it to the shop where u got it...
Dec 25, 2009 | Computers & Internet
My laptop touchpad stopped working
this is probably a driver issue if you are lucky other wise the touch pad must have become faulty
if its a driver issue go to this site
http://www.synaptics.com/support/drivers
and download the drivers according to your operating system
install them and check if the touch pad starts working
if not then its probably a physical fault and needs replacing
Sep 29, 2009 | HP Compaq Presario CQ50-110US Laptop
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
67 people viewed this question
Ekse
Alun Cox
