Question about Epson Stylus C48 InkJet Printer
After cleaning the heads a screen came up and said
I have a Epsom Stylus C48, cheap but more than adequate for what I print. After cleaning the heads a screen came up and said service required. Parts inside your printer are at the end of their life. See your printer documentation.
I went to ask a man in a computer shop and he said that the ink tank needs cleaning out and then printer counter reset and I would find how to do that on line, if I know where to look. So I am really hoping you will be able to help. I know I could just go and buy a new one but I recently bought loads of ink for it and as it prints every thing I want to print it seems a waste.
  • 4,041 Answers
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
You need to be handy with your hands, you will have to open up all the printer to get inside it where you will see the ink tank with pads in it need to clean all out, when you get the time.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on May 08, 2010
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Epson stylus c48
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | Epson Stylus C48 InkJet Printer
Both light flashing cleaned the ink pads
1. it seems that you have clogged print head.
2. you will have to replace the print head or remove them an clean them properly with proper clean solution such as denatured alcohol. Depending on the type of print head manufactured. Some times the print head can be shorted and the printer will not recognize a connected print cartridge.
Apr 19, 2010 | Epson Stylus C48 InkJet Printer
Epsom R220 printing wrong colours
Print a nozzle check pattern then clean the heads until nozzle check pattern returns to normal. If you are using cheap **** compatible inks, throw them out and get some genuine stuff to run in the cleaning routine. Cheap **** compatible ink makes the situation worse when cleaning.
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Print alignment and cleaning heads
this is the utility present on epson printer software itself, go to control panel select printers, then select the c48 right click on it, go to printing preferences, then select maintenance
Aug 15, 2008 | Epson Stylus C48 InkJet Printer
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Service required error
Possible that the waste ink collector is full. (When you clean the cartridges, some ink is used, and that ink has to go somewhere!)
Might be worth having a look at http://www.fixyourownprinter.com/forums/inkjet/31526
(at your own risk, of course :) )
Jan 02, 2008 | Epson Stylus C48 InkJet Printer
Cartidge problem
Many "compatible" cartridges are badly manufactured or even labeld wrong. These can damage or block the connectors on Epson printers. your best bet is go buy new ink and try them, then if it still dont recognise, you could buy some ink cleaning cartiridges and give them a try - Google "Epson Print Head cleaning" Failing that go buy a new printer - Epson's are real cheap new.
Sep 08, 2007 | Epson Stylus C48 InkJet Printer
Epson Stylus C48 InkJet Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
