Question about Sanyo Vpc-s1070w Digital Camera
Lens error 1x15110000
I can turn the camera on, at first it said "lens error 0x00110000" and now it says "lens error 1x15110000". The shutter never opens. Can I fix this myself?
    Sergeant:
  • 420 Answers
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 15, 2010
Shutter is stuck open on the digital camera w1200. When i turn it on the shutter goes in a little than tries to go out and it makes this weird loud clicking noise and i cant see a screen and when it is...
I think what you're referring to is the lens assembly not moving in and out correctly. The shutter is inside the camera out of view. Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 16, 2011 | General Electric W1200 Digital Camera
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
The camera screen stays black, and I can not see anything through viewfinder or on the screen. When I take pictures, they are completely black. Is the camera worthless now?
It sounds like the CCD has gone bad, in which case, the camera is not getting repaired, since it sits on the main circuit board, and you would have to buy the entire board, plus pay the extensive labor. There may be a chance that the shutter is stuck closed, and you might try some suggestions I ran across on a web blog. The blog deals with error messages and lens assembly problems, so it's worth trying:
Hope this helps.
Jul 07, 2010 | Canon PowerShot S3 IS Digital Camera
When turned on, my VPC S1070 shows
This blog explains the problem you're having, and things you can try to fix it.
They say about half the cameras can be fixed, trying their suggestions. Good luck, hope you're in the "fixed" half!
Jun 10, 2010 | Sanyo Vpc-s1070w Digital Camera
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
104 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
