Question about Sony Playstation 3 (PS3) Console
Ps3 hard drive file systems corrupt fixes and then reboots
When ps3 turns on says hard drive file systems corrupt the tries to fix the problem. It does and the reboots the systems and repeats the cycle again.
  • Sony Master
  • 12,061 Answers
You most likely need to replace your HDD. How to do it links below.
www.gamespot.com/features/.../index.html -
vgstrategies.about.com/.../ps3cheatsandcodes/.../PS3HDDUpgrade_7.htm kotaku.com/.../upgrade-your-ps3-hard-drive-step-by-step
Posted on May 08, 2010
Code 80010514
the solution
Ok so I've fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot ... I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don't make a mistake!! Sorry, I had to say it, I don't want anyone mad at me if they make a mistake, don't back up their data and erase it, and then blame me...
The current version of the ps3 firmware has a "recovery console".
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like "you have Corrupted System Data. Your PS will now replace this data" Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren't corrupted) back to the flash memory which is corrupted thus fixing the problem
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Disc not being recognized.
The current version of the ps3 firmware has a “recovery console”.
You access it by
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem.
Aug 21, 2010 | Sony Video Game Consoles & Games
Cannot get ps3 to turn on bought it used and have never touched one before. trying to see if it even works do i need a controller to turn iton or should it power automatically.
It should turn on itself but you can try the following to see if the flash memory is corrupt.
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
You access it by
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Apr 01, 2010 | Sony PlayStation® 3 (60 GB) Console
So i was gone at a girlfriends house all weekend. when i come home to see that my parents had f*d up my ps3. apparently they were watching a movie on it when it all it sudden shut off on them. I got pissed...
You can try the following.....
You access it by
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
File system corrupt? wtf is that
You access it by
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 starts and will run a game for a few minutes but then it will freeze and the screen will start showing green dots dots increase in size too and lines will apear across the screen as well can you...
You access it by
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
My cousins ps3 is not reading the ps3 games how can i fix it?
you can try a full reset of the flash memory, usually works!!!
You access it by
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
Ps3 hard disk file system is corrupted. what do i do?
benm09
If the PS3 built in repair is not fixing the problem this means that you will need to pull the hard drive out of you system and format the drive with a computer. The link below will walk you through what you need to do.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 03, 2010 | Sony Playstation 3 (PS3) Console
Just set my boys pse up put a game in and error
take a look at this site it help me fix mine
http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/
Ok so I’ve fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot … I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
You access it by
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
132 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
