Question about GE CustomStyle 21.5 Cu. Ft. Side-by-Side Refrigerator - Black-on-Black
ICE CUBE MAKER CHANGED. STILL GETTING DRIP IN BACK WALL
    Sergeant:
  • 144 Answers
Than you have to call the technician only to sort the issue because this is due to some technical issue in cooling system. Kindly sort it as soon as possible to avoid rusting of walls.
Thank you.
Posted on May 08, 2010
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Freezer built up ice
This was answered on the page with the model number=>HERE
Model Numbers are easy to forget here but Very Important! Thanks, John Tripp Appliance 911
JENN-Air JFC2089HT
67006531 Water Inlet Valve
Jan 23, 2014 | Refrigerators
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
Ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker not making ice
a few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
GE CustomStyle 21.5 Cu. Ft. Side-by-Side Refrigerator - Black-on-Black Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
