Question about Tomtom GO 910 GPS Receiver
Green light coming on but not working . TRIED THE PAPER PIN STILL NOT WORKING
  • teetoyin May 08, 2010
    Thanks but is out of the warrantee
    Sergeant:
  • 144 Answers
You have to contact the customer care or a technician to see the GPS unit directly and sort the problem.
Thank you.
Posted on May 08, 2010
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
When i turn on printer, green light comes on. when i try to print with my hp laser jet 2100 printer, the orange light comes on. i have to press the start button (biggest round button), sometimes several...
Check the paper tray settings and make sure they are alinged with they type of paper you are using. (Ex. Letter) These settings have to be perfect in the tray so the printer knows what paper is in there. Usually when this happens the printed is asking you if you want to use the tray anyway and by pressing the button you are saying yes so it prints. Try loanding the manual tray with letter paper and see if the same thing happens.
Jan 17, 2011 | HP LaserJet 2100 Printer
Hi have samsung ml 2240 printer top light is flashing green orange and red and the bottom light is flashing red have changed the toner cartridge but printer still not working
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Jun 21, 2010 | Samsung ML-2240 Laser Printer
Computer will not start.
Hi friend.
I think your power system not working properly so you need you check your power. if power is ok...then check your RAM Should be connected my motherboard. then your problem not resolve ...you need to contact any computer hardware Eng. they will check it
Dec 19, 2009 | Dell Dimension E510 PC Desktop
I just replace the power supply and still not working
If all the power cables are attached to the motherboard (normally about 2 different cables), then:
1) Rule out the switch: follow the small cables that come from the power switch to the motherboard...pull it off the motherboard and try using a paper clip to "short" the jumper pins that the switch was attached to. This simulates the power switch being pushed. If that doesn't work then.....
2) Motherboard may be bad
May 07, 2009 | Dell PowerEdge 2300 Server
Plugged into car power but system will not come on
try a hard reset using a paper clip, insert it in the little pin hole on the side to reset the unit. if that does not work plug in your car charge and make sure the green light is lite on the charger..let it charge for awhile then hold the power button for upto 15 seconds till it starts. if that fail,you might have a bad usb port which is a common problem with these and many gps units.
good luck
thanks for using fix ya
Apr 05, 2009 | Magellan RoadMate 1430 GPS Receiver
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Will not power on
This is a tricky problem. You would be thinking that if green light comes then everything is working fine. But that doesn't satisfy the system. Make the ATX power connector of SMPS(Single Mode Power Supply) is properly plugged in or not. The glowing of green light because of the small power connector (4-pin square connector) beside the processor fan. There is one more power connector i.e., ATX power connector. i guess its 20 pin. plug in properly and then try. If again the same problem occurs then you need to replace the SMPS itself.
Thank you........
Sep 28, 2008 | E-Machines eMachines Refurbished EMA...
Tomtom GO 910 GPS Receiver Logo
298 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
