Question about Compaq tc1100 Tablet PC
I get cant launch executable the launchAnywhere
I get 'cant launch executable' 'the launchAnywhere properties file is missing' when I start my computer. I think its someting to do with Java.
I also get that message when i try to open a program
Cant download play store
How to install
The installation process is pretty simply, but there are a few options you'll have to check in your handset's menus before we begin. So here's a full step by step guide to access all that glorious Google Play content on your Android smartphone or tablet.
1- Firstly you'll need a copy of the official Google Play Store apk file to install on your device. You can download this on your PC and move it over to your handset or download it directly onto your handset, in which case it will appear in your download folder. Either way is fine.
The latest version of the Play Store is 4.4.12, which can be downloaded from here, along with any older versions.
The download listed here is cryptographically signed by Google, so it's safe to install and hasn't been tampered with or infected with malicious software. But be aware of downloading files from other less reputable sources.
2- You'll need to enable the installation of external apk files before you can install the Play Store file. This is done by checking the "unknown sources" box in your devices settings, which will allow you to install apps from unvetted sources, in other words from outside of the Play Store. This option can usually be found under settings > security, but may also appear under settings > applications on certain devices. You can always uncheck the box again after installing the Play Store.
Next you'll need to locate where the apk file is on your handset. As already stated, if you downloaded the file using your device it should appear in your download folder, which can usually be accessed from the app drawer. However, if you had to move the file on your handset from your PC via a USB cable, then you'll need to be able to navigate to wherever you put the file. The easiest way to do this is to either directly place the file in the download folder, or install a third party file explorer, such as ASTRO file manager, in order to locate the apk.
4- Once you've found the file, tap on it to get things started and a popup will appear asking you if you want to continue with the installation. If this isn't working, check that step 2 has been completed successfully.
5- Continue to click install, passing through the list of required permissions that the app requires. A loading bar will appear, once that's completed the app is installed.
All done, it's as simple as that. Now you're ready to launch the Google Play Store and begin downloading apps.
if this does not work, please reply with the exact error code
Mar 25, 2014 | Irulu 7" Touch Screen 2gb Android 2.3...
Saving pictures to sd card
Click on the "Apps" button and then "My Files". This should launch the files manager.. Be careful but once you find it and select it (a green check-mark will appear in the box) the "Move" button will appear in the upper right between "Copy" and "Delelte".
Mar 08, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Usb debugging, there are no drivers I could find anywhere
You have to run a ADB program on the PC.
This sends commands to the android to execute it.
Mar 01, 2014 | Kocaso M760B Tablet
Windows xp not start following file missing corrupt system32 confi
Restart the computer, and force it to boot from the Windows XP CD-ROM. Choose "Repair Existing Installation", and see if that fixes the problem.
It might be better to remove the disk-drive, attach it as a "slave" disk-drive in some other computer, and copy all your files onto an external disk-drive.
Feb 27, 2014 | Toshiba Portege Tablets & eReaders
Where do I go in the system to set the default storage to the sd card?
SD storage card restore to defaults
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Take Off Write Protection on an SD Card
Secure Digital (SD) flash memory cards are a common storage format for mobile devices.
By default, they allow both reading from and writing to the card.
However, they can be set so you can only read from the cards and not write to them.
Some cards are created as read-only by default.
Other times, a faulty card reader may mistakenly read all cards as read-only.
In both cases, you can make simple changes to the card to disable the write protection.
1.
Orient the card so the label is facing up.
Slide the write protection tab, which is located on the left side of the card, to the unlocked position.
If there is no write protection tab, skip to Step 4.
2.
Test the card in your computer.
Insert the card in the SD slot and open the folder to view the files.
Try to save a file onto the card or right-click an existing file and select "Properties," then uncheck the box marked "Read-only."
3.
Remove the card and check to see the write tab is still set to "unlocked" if you get a message that says it is still write-protected.
If it has become locked again, slide it back and tape it in the unlocked position.
4.
Place a piece of masking tape over the notch in the SD card located on the right side of the card. Make sure the tape does not cover any of the card's metal contacts.
Test again as in Step 2.
5.
Cover the notch with a second layer of tape if the card is still giving you problems.
http://www.getflashmemory.info/hack-why-is-my-sd-card-write-protected/
Aug 15, 2013 | Avatar Sirius S701-R2A-1 4GB NAND Flash 7"...
Kindle fire hd lockscreen
Prerequisites:
1. Kindle Fire HD 7", Kindle Fire HD 8.9" or Kindle Fire 2
2. Rooted Kindle: http://forum.xda-developers.com/show....php?t=2069117
3. Google Play: http://forum.xda-developers.com/show....php?t=2069329
Custom Locker Step 1. Using Google Play, search for "No Lock". Download and Install No Lock - You may use this link to verify the software: https://play.google.com/store/apps/d...d.nolock&hl=en
Custom Locker Step 2: DO NOT Open No Lock, it will fail. Next, go to the Kindle, open up ES File Explorer or Root Explorer
Custom Locker Step 3: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find org.jaf.androidnolock-1.apk - long press on the APK, select Move or Move To. Next, Move org.jaf.androidnolock-1.apk from /data/app to /system/app.
Custom Locker Step 4: Next find org.jaf.androidnolock-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 5: DO NOT Open No Lock. Pull down the Upper Status Bar, Select More+, Select Sounds & Display and change the Screen Timeout to: Never and then reboot the Kindle.
Custom Locker Step 6: Once the Kindle is back to the desktop, open No Lock which is found in the Kindle Apps, select "Locking disabled".
Custom Locker Step 7: Using Google Play Search for MagicLocker Main which you can find here: https://play.google.com/store/apps/details?id=mobi.lockscreen.magiclocker - Download and Install Magic Locker Main
Custom Locker Step 8: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find mobi.lockscreen.magiclocker-1.apk - long press on the APK, select Move or Move To. Next, Move mobi.lockscreen.magiclocker-1.apk from /data/app to /system/app.
Custom Locker Step 9: Next find mobi.lockscreen.magiclocker-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 10: Using Google Play Search for MagicLocker Theme - Download and Install a few Themes that interest you. I use Starry lock screen and Jelly Bean lock screen.
Custom Locker Step 11: Launch MagicLocker Main, click on Next, Next, Next - You will now see a popup, click Next and choose Clear Defaults until it Grays Out, click on the picture of a house (Home Button), you will be asked which Launcher to Use, you choose MagicLocker Main <Select Default>.
Custom Locker Step 12: Launch MagicLocker Main, sometimes you are taken to your regular Launcher App, if this happens repeat Step 11. Select "Lost Robot Music" and click Apply. Next MagicLocker applies the Theme and asks if you would like to Customize it, answer Yes or No depending on your interests. I selected No so we can move on. You can always customize it latter.
Custom Locker Step 13: Next MagicLocker will show you an example of the Theme. Unlock it by pulling down the circle in the Android Picture.
Custom Locker Step 14: Now we need to customize the way MagicLocker reacts when you unlock to the Left which is a Phone Call and when you unlock to the Right which is a SMS Application. Unlock straight down just unlocks the screen.
Custom Locker Step 15: OK, lock the Kindle by depressing the Power Button for 1 brief Second until the screen turns black. Depress the Power Button briefly again, you will see the lock Screen. Unlock to the Right, next you are asked which is your SMS Software, I use Go SMS Pro. Check the Box to "Always use this application". Unlock to the Left, next you are asked which is your Phone Software, I use Google Voice and Groove. Check the Box to "Always use this application".
Custom Locker Step 16: Next, let's install the Themes. Find the name of the Themes you downloaded in Step 8. In this example we picked Starry lock screen and Jelly Bean lock screen. So go into the Apps. Find Starry lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu. Exit MagicLocker, then go to Apps, find Jelly Bean lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu.
Custom Locker Step 17: Now we need to let MagicLocker know what is your Default Launcher, so launch MagicLocker, find Preferred Home Launcher, click on Preferred Home Launcher and select your Launcher, we use Nova Launcher Prime.
Custom Locker Step 18: Let's eliminate the Ads from ever appearing again. Open either ES File Explorer or Root Explorer, navigate to /system/app find the dtcp_apk.ap, long press dtcp_apk.apk select Rename. Rename dtcp_apk.apk to dtcp_apk.old.
Custom Locker Step 19: Reboot the Kindle.
Custom Locker Step 20: Whenever you reboot, the Kindle Fire Framework starts before anything else, so you may see the Kindle lock screen at Reboot IF you do not let everything start. If you can not wait 5 to 10 minutes, unlock it and let all the services start, usually 10 minutes is sufficient. Once you unlock it, you will notice there are no more Ads! After 10 minutes No Lock Service kicks in and disables the Kindle Fire Lock Screen. We have attempted to play with the start-up timing and ended up with Framework missing, so Amazon was smart when they thought out this function. Also, the service that controls the lock screen is part of the same group that displays the Kindle Framework when you unlock it. Finally, if you do wait 10 minutes you will never see the old Kindle Fire Lock Screen!
That is it! Next we will offer you a solution with the stock lock screen but you will need high resolution photos to make it function properly. Be sure to look at our new Backup and Recovery Software for the Kindle Fire Series: http://forum.xda-developers.com/show....php?t=2096888
May 31, 2013 | Amazon Kindle Fire HD
I cant find my serial number
if you are trying to recover a key there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html
Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency. This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window. Single-button clicks copy all keys to either a text or HTML file.
http://download.cnet.com/product-key-finder/3000-2094_4-10694022.html Product Key Finder is a single function utility that executes in a GUI, but displays a Command window result. You merely double-click it to display the 25 character Microsoft Windows Product Key.
http://download.cnet.com/keyfinder-thing/3000-2094_4-10491989.html Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency.
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
if you still cant find it
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: keyfinder you might have to try a few times to get it right
hope it helps
Jun 18, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
How do i download kids e books to the tablet?
You can put eBooks on the tablet by using the Aldiko eBook app and your PC to put books in the library.
1) Download an ePub file to your computer. Use Google Books or another eBook store to get the file. Check out http://books.google.com
2) To transfer the ePub file, hook up the tablet to the PC.
3) First mount your USB Storage (Internal), from your PC go the removable disk, you should see the ebooks folder, create a sub folder and name it import.
4) Copy your epub file to the import folder.
5) Next turn off USB storage(Internal).
6) Launch Aldiko, click on Menu which should popup a menu with option such as import. Click on import. It will start to scan your sdcard for any epub files.
7) When the import is finished, click on Bookshelf to refresh. For some reason it just doesn't see any epub files from the USB Storage (ie from the MicroSDCard)
Let me know if this helps.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
I deleted a dll file for my omnipass
Try booting up into safemode.
Reboot your pc.
Keep pressing F8 before you see the windows logo.
If you did it right, you should come to a screen where you can select Safemode.
If that doesn't work call Fujitsu support and ask for a recovery disk.
Nov 01, 2007 | Fujitsu LIFEBOOK P1510D Tablet PC
Compaq tc1100 Tablet PC Logo
290 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
