Question about GE Security Simon 3 Wireless Home Security System
Hi, I have a galaxy 8 alarm and i accidentally cut the mains wire! My husband has rejoined the cables and the alarm is working on mains and battery but even though the keypad is lit and is displaying numbers, my code wont stop the alarm going off! its not beeping when i press any of the keys! Could anyone give me some advice pleaseee..thanks in advance, rebekah
NEXT TIME ACCIDENTALLY **** YOUR WRISTS... AND THAT SHOULD FIX ALL YOUR PROBLEMS
Posted on May 10, 2010
Metza alarm removal on honda varadero xl 1000
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to remove any Security Alarm Dye Tag in 2 Seconds
Misc
Honda Varadero MK1 XL 1000 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/honda/227
Feb 03, 2014 | 2005 Honda XL 1000 V Varadero
Hi I have 1997 polo 1.4 recently replaced starter motor and all I get is one click then it cuts the battery out and the alarm goes off any suggestions?
Check if the two smaller wires on the starter motor next to the main supply cable are connected .If you short the two terminals on the front of the starter with a screw driver it should swing the engine and start it if the ignition is on this will also tell you if the battery has sufficient power in it to swing the engine. the alarm going off tells me those wires on the starter are not making good contact creating a short which could trigger the alarm.
Jun 06, 2013 | Cars & Trucks
Ge air conditioner error code ep
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Apr 23, 2013 | Heating & Cooling
My ge AEW18DMG1 window unit shows an error code EP. What does it mean?
Jun 01, 2012 | GE Air Conditioner Main PCB - WJ26X10241
Hi, I have a 1995 Toyota 4runner... That said, I'm
Well if they were able to cut this wire, I am assuming they were able to get into the car? But if your dad can open the hood and take the negative wire cable off of the battery then he can bridge the wire that was cut, hopefully.
He will need a small wire clamp kit that they can get at an AutoZone or Atuo Parts store. After he fixes the wire that was cut, he will need to disconnect the positive wire cable from the battery and then reconnect both of them. that should keep the alarm from going back off, however it may reset the system. Either way if he has the spare remote they should be back in business and can get your care moved and the alarm to work again.
Good Luck!
May 29, 2012 | 1995 Toyota 4Runner
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
I get an error code EP on my GE room Air conditioner. what does this mean? i did what someone suggested and unplugged it; replugged it and reset it; still did not work,.
Sep 10, 2010 | GE AJCQ08ACB Air Conditioner
I have an GE air conditioner with ''EP error code, and compressor stops.
Jul 01, 2010 | GE Heating & Cooling
Disalarmed - cannot now reset, no alarm
Drop down the dash and locate the alarm module(generally a black box) find two thicker wires going to or from the ignition. at the ignition end check to see if these two wires are attatched to a wire coming from the ignition that has been cut and joined to the two alarm wires ,if so cut them and rejoin them,this will get you home.Then go to a tech.
Apr 10, 2009 | Vehicle Parts & Accessories
Ford galaxy central locking problem
It´s probably a cable problem. There are two cables between the motor in the door, and the control center. In my case one of the cables where cut of do to to many door openings. Every time you uses the door the cable bends. In the long run it cuts.
Jun 17, 2008 | Car Audio & Video
GE Security Simon 3 Wireless Home Security System Logo
134 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
