Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do I disassemble the top part of the agitator on Whirlpool II Ultimate Care washer.
The bottom part of the agitator works fine, but the top part does not work properly. How can I get the top part of this off? Is there a place I can get a repair manual for this product?
  • 7 more comments
  • pahopson Apr 02, 2008
    Thank you soooo much. This is amazing! After I got in there, I found that it was the agitator dogs. I got the part from Whirlpool and it is now working like brand new! Again, thanks SO much for your help. Have a great day! Phyllis Anne
  • 2gether Apr 12, 2008
    my wash machine agitator doesn't work and the machine is making a grinding noise and it doesn't spin.
  • Anonymous May 04, 2008
    I need to remove the top part of the agitator. The plastic part that grabs the interior part of the top section has worn the "grabber" and is broken. Where can I get this part and how do I get it off.
    Thanks
  • dave76525 May 04, 2008
    how do i dissasemble the agitator now that i have it off? the bottom agitates fine, the top part will when empty but clothes weighing it down does not allow it to engage the dogs i guess, and it doesnt move back and forth, only one direction. worn dogs? ok but gotta get to them. thanks
  • hornblower2 Aug 13, 2008
    I have removed the entire agitator assembly, but don't know how to remove the upper agitator from the lower portion.
  • Armin Buehlmann Nov 08, 2008
    I have the same exact problem, but answers to previous posting are no longer available. The expert store sold me new dogs but could not give advice how to disassemble. Placing agitator on the floor and pulling on top half doesn't work. It appears that the agitator on this commercial model (3357978 stamped on rear) has the ratchet assembly molded to the bottom half of the agitator. Is this true? How do I disassemble it without breaking it for future use?
  • Anonymous Dec 06, 2008
    The top part won't come off, and the video has been pulled off YouTube.
  • jamidei Dec 12, 2008
    Where can I get info on this subject? I have the same problem as all these other posters.
  • babydoll78 Dec 16, 2008
    same problem as everyone else
    President:
  • Whirlpool Master
  • 2,651 Answers
Gotta love the internet!!!!!! heres your procdure
http://www.youtube.com/watch?v=f67gGXtK2I0
Posted on Apr 02, 2008
    Problem Solver:
How to change the timer on a whirlpool washing machine. Model LSN1000LW3. Top load
Posted on Sep 01, 2011
SOURCE:
  • 112 Answers
SOURCE: How do I disassemble the top part of the agitator on Whirlpool II Ultimate Care washer.
The top cover just pulls off, then as you look down the center of the agitator, there is a round plastic cap that just pulls out. You may have to tug hard for either or both of these. Then there is just the center bolt that you take out and the entire top of the agitator will come off. Usually, the "dogs" in the agitator wear out and need to be replaced. Cheap and easy fix. Note: you may want to get a new o-ring for your cap when you take this apart.
Posted on Oct 18, 2008
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Posted on Jul 14, 2010
oldTech2332
  • 2341 Answers
SOURCE: How do you disassemble the agitator for a
i am assuming that you want to do that to replace the agitator dogs? this vidoe will show ya how to remove the agitator and replace the dogs.......http://www.youtube.com/embed/0GQh8JLqVv8" frameborder="0" allowfullscreen>
Posted on Jul 18, 2011
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hello, the agitator seems to work (and turn) well at the bottom but it seems stuck at the top (hardly turns. What can I do? Thanks, Isa
If it has a fabric softener dispenser in the top, it is most likely a waxy buildup from the lanolin in the softener. Disassemble and clean.
Sep 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you disassemble the agitator for a whirlpool ultimate care ii?
Jul 18, 2011 | Whirlpool Ultimate Care II GSW9650LW Top...
Why would the agitator spin freely? It's not
The agaitator dogs are worn out or broke. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the disassembly and replacement.
Mar 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Top agitator does not move on a whirlpool LSN100KQO Ultimate Care II commercial washer. how can i repair that?
I have run into the same problem and spent some time with it. There are little pieces that catch and release the top aggitator called dog agits(dogs). They are cheap and easy to replace but the problem is this aggitator is put together so that the top and bottom piece do not come apart. I dont know how this will resolove.
Oct 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I separate the 2 agitator parts on a Whirlpool LSQ9549L?
that part snaps in you need a long screw driver to free the snap on the inside where the nut is don't pry on them too hard you'll brake them
Apr 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
2,545 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
