Hi there, I have a middle aged daewoo tv and the
Hi there I have a middle aged daewoo tv and the sound keeps dropping in and out. I suspect the scart sockets are at fault as when these are touched the problem is affected. Any easy fix?
  • 189 Answers
HI
I one had a Daewoo Tv that did pretty much the same thing and it was caused by dry joints on the scart socket pins which are soldered to the board. It's possible the pins that hold the scart plug connectors may be slack, these can be tightened very gently by pushing them together with fine screwdrivers (not too much pressure).
That's all you can do!
Posted on May 08, 2010
I have a very elderly Philips CRT type TV previously owned by my late father. We use it for our grnadchildren to watch VHS tapes when they visit us as the live TV facility went with the switchover to...
hi if the tv has a scart socket plug scart lead from tv to settop box and it should work fine
crt model numbers are usually right at the back of tv at the bottom under the big bump on back sometimes on the side sometimes even underneath hope this helps need more info please email me
Jun 23, 2011 | Philips Televison & Video
I have a baird OR42BAFHD tv and am trying to connect it to my hi-fi. The hi-fi only has the usual auxillary red and white input jacks but i cannot see were i can connect them to the tv which has several...
Hdmi is digital minded while your hi-fi is analogue signals, you have two possible options I think if your TV has no phono audio out.
Your scarts (number 1 only) will have analogue in's and out's a scart lead with audio in/out to phono (come with a switch mostly) or adaptor is required some I have seen at one time had a plug one end and socket the other with output phono's in the middle, so to monitor signals going each way (TV > VCR or VCR > TV).
If you are not using the scart then just a simple scart to phono will do, note scart sockets on an TV only one will give an output.
The other route is a converter for hdmi a device that will convert digital signals to analogue, while the video element can have problems (on cheap units) through poor design/technicals the audio should present no problem, look for hdmi to audio converters.
Hope this helps.........
Sep 26, 2017 | Televison & Video
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My set does not have a scart socket to connect a freeview box - is an RF modulator the kit I need?
hi,
you can use a SCART to audio video converter to connect it to your tv's AV in put.(one side SCART and other side 3 RCA for audo and video.
ok
Feb 01, 2011 | Aiwa VX-T1470 14 in. TV/VCR Combo
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
When using the middle scart connection tv is black
while watching the set and using the middle connection move the cable connector up and down, side by side and see if the color comes in sound like a bad/ broken connection on the scart connector on the printed circuit board
Jul 07, 2009 | Televison & Video
TV going black still hear sound
I suspect if you are using the DVD to play via a Scart connector , then the problem is simply that the Scart cable has became a bit slack. Try taking the Scart out of the rear connections from the DVD & the TV & then just pushing them back in again to make sure they have a good contact.
Apr 04, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Whaere is the scart lead?
http://www.e-daewoo.com/products/owners_manual/DTS42(English).pdf
Please have a look at the above user manual from the Daewoo site. You may need to down load the Adobe PDF reader if you can't open the file. You can get that from this web site;-
http://www.adobe.com/products/acrobat/readstep2.html
I am not sure that this is exactly your model but one page of the PDF document , page 14 shows the connections at the back of the TV with no obvious SCART connection. So I think you will have to connect the two using a component video cable and the Left and right audio cables as show in the manual on page 28. or via an s video cable and right and left audio cables as show on page 30.
If the connections in this manual look about right for the connections on the back of the your TV set I would be tempted to take this manual printed out (or just the image of the back of the set page 14) down to your local TV shop with the Freeview box and ask them what cables they recommend you use to connect the set.
Also be aware that cables from these TV shops cost a fortune and you can probably buy the cables cheaper on eBay once you know which ones you need. Without seeing the freview box its hard to know what cable options that box offers you.
Regards
Aug 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
I have a Daewoo DS608P Freeview box which will not detect any chennels. The pre=scan and scan appear normal, but nothing is detected. The TV, which has no Scart socket, works fine on analogue, and I have...
Sorry to be the bringer of bad news but the transmission mode in the uk is changing & that is why your box will not pick up any channels have a look on http://www.freeview.co.uk/help/faq/id104963 I'm affraid your box is finnished.
Jul 25, 2008 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
