Question about Electrical Supplies
I have a yamaha ec 5000 dve industrial generator that wont start. Its been sitting for about 6 years now but it ran great last time it was used..
  • 5,603 Answers
If it is a diesel, bleed the fuel lines at the injectors. Also verify the fuel valve is opening. If it doesn't, the bleeding operation will show that as well.
The tiniest bit of air in the fuel lines prevents the injectors from getting fuel.
If the unit is gas engine driven, check all the usual things, spark, fuel, etc.
Posted on May 09, 2010
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
I have a yamaha ec 5000 dve industrial generator that wont start. Its been sitting for about 6 years now, but it ran great last time it was used..
If it has been sitting to 6 years then the gasoline is no longer any good. Drain the fuel tank first thing. Remove the float bowl from the carburetor and drain the fuel and clean it out. Put in fresh fuel and try to start it. If it still will not start try using starter fluid to see if you can get it going. You may in the end have to disassemble the carb and clean it out.
Apr 21, 2010 | Tools & Hardware - Others
I have an EB6500 that was sitting for a while. When I started it it ran fine then after 3 minutes the generator head smokes and you get that electronic smell,even without turning on the main breaker.
Is that all you ran it was the one time? Sounds like a mouse. Or bugs got in there and built a nest, something just burning off. Get the air gun on that thing and blow it out, then try it again, hopefully it is just dust and dirt piled up in there.
Mar 01, 2010 | Honda Mmd 5000 Watt Electric Start...
Yamaha yg2800i generator will only idle
My guess is that while it was running out of gas the balnket and heater was pulling a load that the generator could not keep up with. Do you still have the manual????????
Mar 25, 2009 | Yamaha 2500 Watt Industrial Inverter...
Electrical Supplies Logo
378 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
