Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Low wireless signal wbr 2310 on signal strength
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
Posted on May 08, 2010
2 Suggested Answers
indus3
  • 212 Answers
SOURCE: low wireless signal
when a wireless router has signal strength issues, there usually is a firmware upgrade, which you can find on the manufacturer's website, that may solve this problem by upping the db of the wireless transmitter.
Posted on Apr 20, 2010
I have a WBR 2310 I am trying to set up as a extender. Picking up a hotspot ssid dlink. Signal is weak and sometimes usable. Want to strengthen the signal to use with my home system. I have tried several...
More likely it has to do with the channel and how it is is from router. If you have a smartphone download app Wifi Analyzer and see which channels are interfering. Here is the way to log on to your extender and intructions. https://www.wikihow.com/Set-Up-a-D-Link-WBR-2310-Wireless-Router
Oct 07, 2017 | D-Link RangeBooster G WBR-2310 Wireless...
Win7 & vista keeps losing connection with WBR-2310 router
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
• Change the channel on your access point or wireless router.
• Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
• 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
• The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
Nov 11, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D link router a outdoor antenna which isadvertised for a 3 mile range. I am about 2oo yards from the antenna. My computer indicates a the signal strenth as good but i keep dropping off the net....
please observe signal strength as when you are connected to network and till you drop off, there may be distraction in signal strength while you are connected and when you check it again, it comes to good again.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Low wireless signal WBR 2310 on signal strength
Apr 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Router connection shuts down every hour or so
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
No wireless signal on my wbr-2310 router, i need to plug in to fix it???help!
Yes, can you plug directly in with an ethernet cable? type http://192.168.1.1 or http://192.168.2.1 there should be a web menu pop up.
Jul 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
We just bought the d-lin wbr-2310....
there is no any other special settings if u keep the laptop very far it will not receive the signals >try this login to ur router and change the wireless channels use 1>or 11>it may help to improve the signal strength>and check with antena on the router weather its straight>rate me solved if its help full
Nov 04, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
154 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
