Unit powers on fine, but will not play a
Unit powers on fine but will not play a cd. Hhb 830 cd Recorder mfs2004
  • David Dunn
    David Dunn May 11, 2010
    What message or indications do you get in lieu of success?
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Live kick drum causes HHB 830 Burnit Plus to stop recording, vibrations?
Absolutely. You are going to have to isolate the drummer from the writer somehow.
We used to put the drummer in an isolation booth.
You can also try building a "foamy box" for the CD writer. The kind of foam you want looks flat on one side, and sine wave like on the other. Put the flat sides out.
Build it with just the front open, and run the cables under the recorder and out the front if length allows.
CAUTION: I recommend using this enclosure ONLY when there is a live drum being recorded live.
This is because prolonged enclosure like this may cause heat issues.
TIP: which ever side faces the drummer, the writer should not be touching that foam wall.
IE - if the rear faces the drummer, the box should be big enough that the rear wall doesn't touch the writer.
Good luck, and let me know how that all works out for you!
(hey, it's easier than suspending the writer with elastic or bungee cords!)
[subnote - yes, that works too, but it's a pain in the **** building the metal frame!]
Feb 25, 2011 | HHB 830 Plus CD Recorder CD Player
What does pma rec mean on the hhb cbr 830 ? it just stops recording
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
User manual
You can get it at www.manualsonline.com,www.manualnguide.com or at their website.
thanks and good luck
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
MY HHB CR 850 NOT READING OR PLAYING JUST FLASHING CD?CDW?....
Machine is confused. The laser lens may have dust on it. open it up and gently clean laser with a Q-tip. My recorder died last night. I wanna' cry. it was very usefull to me with my music. Now I'm screwed after 10 years of owning it. Good Luck
Dec 10, 2009 | HHB CDR850 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Aug 14, 2007 | HHB CDR850 CD Recorder
 Grubhead
Grubhead
