Question about Troy-Bilt Pony Garden Tiller
Need to put used tiller togethher
How do I crank my cub cadet tiller?
Hi I'm Peter, there should be an on /off switch you need to put in the start position then you can pull start it. You will also use this same switch to turn it off.
Oct 12, 2011 | Cub Cadet 1 Rotary Tiller Operator ...
I have a cub cadet tiller and don't know how to start it?
  • Hi I'm Peter, there should be an on /off switch you need to put in the start position then you can pull start it. You will also use this same switch to turn it off. Make sure you have it in neutral also before you try to start or stop it.
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Tiller won't stay cranked
the carb needs a thorough cleaning
May 04, 2010 | Mantis 2-Cycle Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
What settings do I need to change to connect my Acer Aspire 5670 laptop to my LCD TV using the S-video connection?
dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
Jul 28, 2008 | Acer Aspire 5670 Notebook
Troy-Bilt Pony Garden Tiller Logo
14 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
