Question about Dryers
My dryer rumbles when it is spinning. But it also
My dryer rumbles when it is spinning. But it also does not spin at times either. There is heat and when the tumbler does spin the clothes come out very dry so heating is not a problem. I'm just wondering why it does not spin at times and then when it does it makes a rumbling sound? It is a White Westing House dryer.
  • 65 Answers
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
Posted on May 08, 2010
Dryer drum rumbles
Rumbling can be caused by worn drum rollers. Poor heating can be caused by a defective heating element (if electric) or defective burner control (if gas).
Apr 10, 2016 | Dryers
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
My dryer rumbles when it is spinning. But it also does not spin at times either. There is heat and when the tumbler does spin, the clothes come out very dry, so heating is not a problem. I'm just...
Ok you have a simple solution to repair your dryer if handy with simple tools. First purchase a belt for the drum and a roller for the belt tensioner. Sears will sell this in a kit form at any Sears store. The top of the dryer will have to come off then the front panel. The front section of the top will be needed to pry upward to remove upon when you remove the rear brackets on the back of the dryers top section. After removing the top, unplug all electrical connections. all should be diffenerent in shapes and sizes which is helpful to you.
The front panel may have screws on the sides that have to be removed.
Some models has a small secondary lower panel that simply pushes down and pulls out for removal
Now that the dryers drum is exposed you need to pull the straight drum out.
Now you will see the tensioner with the roller attached. The roiller you have on your will probably has a frozen bearing and a flat spot on the roller that causes the thumping noise when spinning. The belt has been stretched by the roller being uneven so long making the drum to stop when using you dryer.
Install the tensioner and weave the belt in through the tensioner and wrap it around the drums backside with a helper helping you
With some help you can slip it back in and reassemble this dryer.
Apr 10, 2010 | Dryers
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Grinding Noise
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Dryers Logo
163 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
