Question about Mantis 2-Cycle Tiller
Engine will not turn over. Plug is clean, fuel mix
Engine will not turn over. Plug is clean fuel mix is correct. Have put straight unleaded into the cylinder and cranked it over will run about six cycles then die. Fuel line seems to be clear..............?
  • 198 Answers
Disassemble the carb and see if the float valve is sticking. it should slide up and down very freely
Posted on May 10, 2010
Will not start someone put wrong flue mix in
You will need to drain the fuel tank and lines, to get rid of the wrong fuel mix. Remove the spark plug clean and dry it. Rotate the engine several times with the plug out, to get rid of some of the wrong fuel mix. Install plug, fill fuel tank with the right fuel mix and start using normal procedures. If it does not want to start, remove the plug and put a teaspoon of straight gas in the cylinder. Install spark plug and try to start unit. You may have to remove the plug more than once and put gas in the cylinder.
Nov 13, 2015 | Garden
Our victa lawn mower is a 2 stroke and someone has put unleaded petrol in it, now it doesn't run, how can I fix it?
Try flushing the diesel out of the system with 2stroke fuel, replace the spark plug and try restarting!
Dec 30, 2014 | Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
Trimmer is producing alot of white/blue smoke, got it to start and it will keep running, but the smoke seems excessive when using it. Not sure what the problem is.
This engine does NOT used mixed gas at all! It uses straight unleaded gas. If your using mixed fuel of any mixture ratio in the engine it is really going to smoke badly. What fuel are you using please?
Kelly
Jul 01, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have put straight fuel in Echo Hedgecutter is there anything I can do, it actually stopped working
does it turn over at all, if not try pulling the head cover off and giving the top of the piston a few raps with a piece of wood and a hammer. Hopefully you didnt sieze it up completely.
Mar 13, 2011 | Garden
What is the gas and fuel mixture for a homelite st-185 weed eater
If it's not been started for that long, ensure that any remaining crud in the tank and fuel lines is cleaned out before even attempting to start it.
Put in a NEW plug, then mix up some 50:1 mix of unleaded and good synthetic 2-stroke oil (Sthil or similar). This will produce an almost smoke-free exhaust, and won't foul the plug.
If it does start, be prepared for LOTS of smoke initially, as all the old oil from inside the engine burns off.
May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
By accident I used regular unleaded gas in my chain saw rather than the premixed 40-to-1 blend I have in another gas can? Th engine ran for a short time but stalled several times before I realized the...
Does the engine still turn over and appear to have compression? The piston and rings take the brunt of this error. Try your solution--but you need to get rid of ALL the straight gas. Remove the spark plug and squirt in some two-stroke oil. Then set the choke and pull the starter through with the ignition OFF a dozen or so times to pull mixed fuel into the carburetor. Open the choke and pull through a few more times. Replace the spark plug and see if it will start. If it does, run it slowly for awhile, then bring up the speed bit by bit. You MAY just luck out!
Jun 22, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mantis 2-Cycle Tiller Logo
192 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
