Question about Rival 38601 Smart Pot 6-Quart
Black liner cracked on bottom
I RECEIVED THIS AS A XMAS GIFT 2007, HAVE USED IT TO MAKE SOUP ONLY, NEVER PUT ANYTHING COLD OR FROZEN IN IT
THIS, CRACK HAS CAUSED FLUID TO GO INTO BASE, THERE FOR
UNABLE TO USE
I AM EXTEREMLY DISAPPOINTED IN THIS PRODUCT
HAD AN OLDER MODEL FOR 20 YRS AND NOTHING EVER WENT WRONG
I WILL NEVER WANT OR WANT TO USE ANOTHER OF YOUR PRODUCTS
STAINLESS STEEL, BLACK INSERT ALSO CAME WITH THE LITTLE DIPPER
LYNN MITCHELL
lmm1190@hotmail.com
  • Anonymous Apr 15, 2008
    my insert did the same thing, i'm looking for a replacement. any ideas?
    President:
  • 2,712 Answers
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Our cermaic pot of our crock pot cracked when using it today is this a common problem its only a year old and has been used two times...
No this is not a common problem.
The ceramic bowl should last for years if handled correctly.
It may have had an unseen stress crack causing the premature failure.
Avoid putting cold liquid or items into the hot ceramic bowl/pot. This will cause the bowl/pot to crack and can be very unsafe when it pops. The reverse is also true, avoid putting hot liquid or items into the cold ceramic bowl/pot.
It is the sudden changes in temperature that can cause cracks to form.
Hope this helps!
Nov 10, 2009 | West Bend 84754 4-Quart
I have a Proctor-Silex crock watcher, mod.#33650. Recently i've noticed a circular hairline type surface crack on the inside bottom area of the porcelain liner. I don't know the severity of the crack. I...
Try calling the manufacturer and tell them you noticed it and you are sure you didn't do anything to damage it. There isn't much you can do to seal it. Good luck
Nov 06, 2009 | Hamilton Beach Proctor-Silex 32190...
Cracked ceramic liner on a 84356 WB Crockery cooker
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot. The cost is $15.00 plus shipping and applicable tax.
Jan 24, 2009 | Crock Pots & Slow Cookers
I need a replacement lid
While useing my crock pot the black handle on the lid fell off all i need is to find out how to get another one. I received this as a xmas gift last year and i realy like it. Please help me with this.
Katherine Keith
Nov 04, 2008 | Rival 38601 Smart Pot 6-Quart
Without thinking I put frozen bratwurst into my Crockpot and turned it on high. Now there is a hairline crack in the ceramic insert. Can I safely repair this before the crock falls apart? What woold be...
I would suggest that by adding frozen goods to an ambient pot and the heater has kicked in causing a crack in the ceramic pot - this is unrepairable as the damage done is deep into the pot.
A similar problem is putting hot water onto a frozen windscreen - it will crack.
The damage is caused by applying alternate extremes of tempatrature to a solid.
You could glue it, but it may well leak later in use, or may not be entirely stable in the wash. You might find it could separate when you are cleaning it.
Sorry, but I hope this helps.
Oct 15, 2008 | Rival 37601 6-Quart
Rival Model # 3150/2 3 1/2 qt. crock pot/ slow cooker circa. 1984
I need a lid for #3150/2; all the rest works great! I'm sad the lid broke (I've had this for 28 years). If I can't find a lid, I'll sell the liner and working outer part for $10 plus the cost of shipping it to you. Let me know at loneill639@numail.org. I just made the best 'garbage' soup ever (all the leftovers including steak, gravy, broth, potatoes, green beans, chopped grape tomatoes). This thing works great!
Feb 23, 2008 | Rival 3100 3.5-Quart
Black ceramic liner
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Cheers!
IrishDruid
Feb 02, 2008 | Rival 38601 Smart Pot 6-Quart
Cracked stoneware
I have spider cracks also and I have a larger crack in the bottom
Jan 30, 2008 | Rival SCV702 Slow Cooker
Broken ceramic
Need a Rival ceramic liner (4 qt) replacement. Where can I find one??
Nov 10, 2007 | Rival 3040-VG 4-Quart
Rival 38601 Smart Pot 6-Quart Logo
35 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
