Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Has good suction but wont move
My zodiac barracuda has good suction but wont move. When it is diconected from the body the hose starts to vibrate. When I attach the hose to body the vibration stops.
    Problem Solver:
  • 5 Answers
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
Posted on May 08, 2010
Sounds like a clogged or damaged diaphragm. Unscrew the nut just above the handle and push the white tube downward until you can see the white(ish) rubber diaphragm. It should not be damaged or distorted. there should be a small uniform gap inside and should not have any holes other than the two ends. Replace if necessary.
Apr 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Good suction, no blockage in hose but very little vibration and it does not move. Cannot see anything but daylight through the cleaner itself. Help!
With cleaner underwater, check suction at bottom of cleaner. If good, then remove diaphragm and check for a rip or tear. If suction low at pump and good at skimmer, check the hoses.
Feb 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda not moving
You could have too much suction, something stuck in the diaprahm, a torn diaprahm could do this or if it is sticking to the drain you will have to shut the drain down.
Jan 10, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda don't move
what do you hook your vacuum to in the pool? does it have suction? it may be clogged. if so you can blow it out if you have the equipment. it may be you don't have enough suction and all you need to do is adjust one of your suction side valves to fix this problem. if you don't have dedicated valves you can plug one of you other suction lines to give your vacuum more suction.
Jul 24, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda not bouncing or moving to clean pool
Check suction at cleaner. Could be broken hose, bad or dirty impeller, incorrectly set valves, dirty filter, clogged line and probably a bunch more things.
May 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
1,185 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
