I have prodipe powered monitor speakers. one of
I have prodipe powered monitor speakers. One of them works fine for 10 minutes or so and then starts crackling. Let it cool down and it works for 10 minutes and starts again. Seems heat related like a component is breaking down. Cant see any dry joints. Any assistance would be appreciated
  • Audio Player... Master
  • 5,056 Answers
It will be a semi-conductor that's causing the problem. All you need to do is get a can of Servisol Freezer Spray. Then when it's playing up spray any of the semi-conductors you suspect (one at a time) with it. If it's the faulty one it should start working. To confirm it, heat it up by touching a leg or pin (IC) with a hot soldering iron to get it to act up and spray again.
Posted on May 08, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
We have a Viewsonic Optiquest Q9B-2 LCD monitor with built in speakers. Worked fine and all of a sudden wouldn't power on. We checked power cords and changed 3-470 caps, 1-330 cap, and 1-10 cap. Monitor...
Probably not yet. Check and replace the power transistor on the source board , it has been surely fried when the capacitors failed. If even after that the source doesn't start then the transformer has been fried.- you will have to replace the entire power board. This will cost you around $75. If you think your monitor is worth that much money then go ahead, replace the board.
If not...
Oct 05, 2010 | Computers & Internet
It will be an IC or transitors that is faulty. You can get it to act up quicker and find the faulty part faster by getting a freezer spray for electronics. All you have to do is wait for it to act up then blast each suspected part with the spray. If it stops acting up you will have found it. But to be certain, warm it up again with a soldering iron and then blast it again.
Don't spray everything, just pick on one at a time!
Mar 30, 2010 | Audio Players & Recorders
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
PF790 monitor picture issue
Was it dropped? If so, it could be a board crack or damage to the CRT. Was it stored in an unheated garage, shed, or attic, etc.? Damp air or widely changing temperatures can cause condensation on the circuit boards. Minerals and other impurities can collect on the board via the condensation, leading to some nasty corrosion. Plus in my opinion, late-model CRT monitors are a real pain to work on. Many of them have so many shields and so many screws that before you get the board free to work on it, you're sick of messing with it! *grin* Then when you do some work on it and want to test it, you have to do a lot of reassembly first. I'm sure others will be tempted to jump in here and tell me how crazy I am, but unless they belong to a family member, I don't even work on them any more. When it comes to monitors, I only work on the flat-panel types. But if you go for it, look for electrolytic capacitors with bulging tops or leaking bottoms, bad board connections, etc. Good luck!
Jan 08, 2007 | ViewSonic PF790 19" CRT Monitor
 Grubhead
Grubhead
