Question about Lexmark JetPrinter X1185 All-In-One InkJet
SAYING COVER OPEN WHEN IT IS CLOSED
Top cover got knocked off on right side put it back on fits flush. Everytime we try to print it says need to colse cover. Is there A sensor that needs to be pushed or covered somewhere?
  • 4,041 Answers
Hi there
Yes you should see it when you you look at the cover there will be some thing there that push it, maybe this has broken but you can put some thing there so it will make it think it closed.
Posted on May 08, 2010
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Install side cover on 455 rancher with chain break
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Feb 10, 2014 | Husqvarna Garden
DM12C no longer automatically shut off
there is a photo eye down inside the paper slot. when you put the paper in it trips the sensor. this sensor get covered up with fine paper clippings unplug machine and take some compressed air or maybe a q-tip and clean the sensor. should be two right across from each other
hope this helps
Jul 26, 2012 | Fellowes DM12C Shredder
C5180 display turned white
Have you tried taking the cover off again and seeing if it prints again and if the display is back to normal. That would indicate to me that the problem could be either a wire being loose at the side cover or possibly a sensor, either way you probably need to take it back to the shop to get it repaired.
Dec 08, 2011 | HP Photosmart C5180 All-In-One InkJet...
I only get half of the serving size I choose and I've noticed that when it is filling the cup, the water in the tank is filling up as well I've cleaned the k-cup, basket, tank and flushed it then ran...
Did you allow the vinegar to remain in your BKC700XL, undisturbed for, 4 hours with the power on, before running fresh water through your unit.....IF NOT TRY THIS, FIRST.....sometimes it takes more then one flush, to clean a BKC700XL,,,,, Please post your results, if this works for you, And even if it does not.
Feb 26, 2011 | Breville BKC700XL Stainless Steel
Replaced the water pump on 96 nissan maxima. timing did not get messed with at all. i had pulled the timing cover but the chain looked good and there was no way it could have jumped time. my obd scanner...
Sounds like you missed connecting something back up. The Knock senser won't make it not run it'll just not let it run at peak power. The OHMs on the sensers just need to be close and your old senser may be just fine. The senser watches a reluctor wheel go by. Did you put it back on? did you put it right side up? It'll fit backwards but it won't line up with the senser.
Oct 27, 2010 | 2001 Nissan Maxima
HP 5600 series Lid won't close properly so can't get anything to print. when I start to try to print the power button and the ink low button both flash but its not short of ink. If I press the resume...
On the HP5650 there is a switch on the right hand side at the top. The switch is flush with the inside surface under the cover. A tab on the right hand side of the cover is supposed to depress this switch telling the printer the cover is closed. If the cover is warped (mine was) or if the tab has broken off, you can manually depress the switch with a pen-point (or just hold the cover at that point) to get the printer to activate.
May 02, 2010 | HP DeskJet 5650 InkJet Printer
Knocking in the valve cover
HI.YOU KNOW I'M GOING TO TELL YOU A STORY ABOUT WHAT HAPPENED TO ME. THE SAME THING AND IT PISSES ME OFF EVERYTIME I THINK ABOUT.IT WAS A BAD OIL FILTER AND IT WAS NEW AND MY BIKE STARTED TO LOSS POWER AND THE KNOCKING THAN IT TIGHTENED UP. THERE WASN'T ENOUGH OIL GETTING TO THE TOP END. HA, I PRAY THATS NOT YOUR PROBLEM. JIMBO
Aug 24, 2009 | 2004 Yamaha YZ 250 F
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
