My laptops sound has been broken for about 3 months now. I have tried everything to fix it but whatever i do wont fix it so anyway how do i fix it?
I had the same problem. what i did was, if you go to you device manager and look for the sound, video and game controllers and look for your sound card [im not sure but most sound cards i have seen are Realtek] If you see it and it has a question mark by it it needs updating you can do this by left clicking then update driver. If not and you know the name of it such as Realtek then google it and you can download it again from online. well that helped me when mine didnt work. hope this helps you
Posted on Mar 27, 2008
How do i fix sound problem with my Asus Laptop?
search for the right sound driver for your laptop module and install it then restart your laptop .
Nov 30, 2015 | ASUS Computers & Internet
How do i fix sound problem with my Toshiba Satellite Laptop.
If you have a loudspeaker icon on your desktop, the drivers are loaded if not installed third party drivers, go to toshiba's web site, download a fresh set of drivers with updates and install them. Reboot and check your sound.
Laptops LCD Televisions Projectors Medical Imaging More Toshiba America Inc
Nov 29, 2015 | Toshiba Computers & Internet
2007 kawasaki Ninja 250r Cranks but wont startt
It sounds like the float needle valves are lletting gas run into the bowl,in turn running gas into the motor,and fouling the spark plugs. Have you noticed if the oil level seems to be going UP,or the fuel level is going down? Kawasaki motorcycles are prone to leaking needle valves in the carbs for some reason. And the longer it sits,the worse its going to get.Try this,...pull the spark plugs and see if they are wet with fuel.Then,unhook the coils,and spin the motor over with the plugs out.If it shoots raw fuel about a foot out of each or ANY cylinder,then that is your problem. JUST BE SURE TO DISABLE THE COILS BEFORE SPINNING MOTOR OVER,AND DONT BE CLOSE TO THE PLUG HOLES WHEN YOU SPIN IT OVER!!
Good Luck!
Sep 26, 2012 | 2007 kawasaki Ninja 250R
My tv says invalid format when I plug my dell inspiron into it
Sounds like you may need to check your video drivers for an update, besides Windows itself find out what video you have Intel or Amd and update thru their website. It can also be that your tv is running at a resolution that your laptop might not support.However most new video drivers allow for custom resolution settings that can be applied besides the native ones in windows.If its a vga cable I almost can be certain that it is not allowing the native resolution of your display.Hdmi will automatically adjust it.Also try hooking the laptop up to a Pc monitor and check for a display if it works on the monitor you need a custom resolution for your tv. Also try a different input on the tv (if ones available) and check it.
Jan 06, 2012 | LG 42LC2D 42 in. LCD HDTV
Brake lights wont turn off
I don't thnk it's related to the tire going. It sounds like a broken or misadjusted brake light switch. It's located under the dash near the top of the brake pedal.
Feb 28, 2010 | 1997 Dodge Intrepid
Laptop freezes
To me, this sounds like this laptop been beat to almost death...i would prepare for a total failure by backing up everything you want to save, and buy a new laptop...
..or pay a repairman about the cost of a used laptop to try to fix what sounds like a bunch of breaking or broken connections....
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Wont load
hi try this
1 with mp3 player off switch lock/hold button to on
2 press and hold rec button on left hand side keep held down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing now dont connect to computer before you do this goto sandisk website and download the latest firmware once downloaded open the file then it will take you through the process of updating the firmware ok
let me know how you get on ok and if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Why is my 360 freezing
this is a defective 360, very common, not an issue with the tv, microsoft would advise calling them and most likely paying them to fix the console, you may be better off buying an elite, they have fewer problems, there really isnt anyway to fix this, unless you happen to have the hardware and software to do so, not to mention knowing how to take it apart repair or replace whatever is causing the problem and then put it back together, the reason i will never own a standard 360 is just this, they break for no reason and quite often, my freinds have them and so do some of my coworkers, out of around 20 people i know that own them only one has an original that has not broken, its also played maybe once a month and even then its only on for maybe 2 hours, I recommend either replacing it with an elite, a ps3, or a wii, youll have far less problems, and just so you know if you dont already microsoft sucks for customer service, they expect you to pay for just about everything and usualy full retail prices, in the end i would be cheaper/easier to just buy another 360
Jul 10, 2007 | Microsoft Xbox 360 Console
Nothing Display in Canon Ixus 750
Explain how broken Does the Screen display anything? If it does but is cracked then clear tape will fix it. If it is 'dead' then nothing will fix it and no repair I would think is possible. But to be sure check your local web site for repairers or even Canon - but possibly not in Bangla
Aug 11, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Computers & Internet Logo
David Payne
David Payne
