Question about Dryers
Fridigare dryer model# FDG336RES2 not heating
  • 784 Answers
Replace the heating element.
Posted on May 08, 2010
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
Door seal on my Frigedaire sise by side gets hot, what is wrong?
I had this once with a Fridigare GLRS267ZAQ4 side by side but it was also heating up water and the freezer wasn't working very well.
My problem was that the coils and condenser in the back bottom of this unit needed a major cleaning and the fan wasn't working very well. Cheap to buy that part and replace yourself. This problem was causing this unit to heat up everywhere because the coils and compressor were not being cooled properly.
I have often found this unit to get ice build up in the back inside wall and had to take a hair dryer to it in order to melt the ice. This mostly caused problems with the ice dispenser and freezer getting warm.
Right now I am having a problem with my refrigerator not cooling well but the freezer is fine. Guess I'll try to defrost the ice and check the coils again.
Hope this helps!
Kyle
Dec 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hello i have a Frigidaire Gas Dryer model # CGR3600A53 it is not heating at all. how much is the heating element for this model and is the repair that tough?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 25, 2010 | Frigidaire FGQ332ES Gas Dryer
If yours is a gas dryer the spark ignitor needs to be replaced
Mar 17, 2010 | Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Fridigare refrigerator model number FRS6LR5EB3 icemaker not filling with water. When icemaker is on under ice cube tray is hot to touch.
If icemaker gets hot, then you may have a faulty valve solenoid on Icemaker.
Before checking the icemaker check the inlet valve at the back of the fridge, and ensure water lines are not frozen.
the solenoid may be tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
