TCL Mod TFW76B03 shuts down after 3-4 mins
TFW76B03 Service Manual shuts down after 3-4 mins
2 Suggested Answers
  • 4 Answers
SOURCE: TCL Mod TFW76B03 shuts down after 3-4 mins
u should press channel + botton
Posted on Mar 17, 2010
My TCL TV is lock on one channell with a podlock showing only the power key is working and i have no remote
Is there a reset button? Have you contacted customer service at TCL? Check your manual?
Oct 06, 2016 | TCL L32D20
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
Intermittant starts running crappy and tcl light comes on
When the TCL light is on usually means there's a problem with the traction control, need to have inspected real soon. Could be a speed sensor.
Nov 24, 2013 | 2004 Mitsubishi Diamante
Engin light and TCL light won't switch off. When
TCL means Traction Control, and you turn it on and off with a switch. But you did not tell us make, model, or year, so we can't tell you how to turn it off or on.
May 04, 2013 | Cars & Trucks
I need service code of tcl 21m62s
Push and hold the volume down button on the front panel of the TV and display button on the remote control for at least 3 seconds. If you wish to know more proceedings to get into the service mode to TCL brand TVs, check this link.
Jan 30, 2013 | Televison & Video
1999 Bonn,the car runs for about 15 mins and shuts down,replaced ignition mod,cam/crank sensors,filters, fuel pump (3) times,because it seems as though after it shuts down and I try the key agian there is...
did you check the connector that plugs into the fuek pump the termianls get burned and that causes multiple pump failures. its the 4 wire connector
Jul 29, 2011 | 1999 Pontiac Bonneville
I have a sharp microwave mod.#r-1870 you can set it for 5 mins.it will run 59 sec.then shut down you start it right back and it will run 59 sec. and shut down again.
i think there are some problem occured with the autocut n timer....its a genuine prob go to any electrician...thnx
Feb 26, 2010 | Microwave Ovens
1984 bronco 2-runs 15 min shuts down wont start again for 20 runs
If the fuel filter is dirty it will settle when you turn the truck off. When it runs for a few minutes the debris in the filter will get sucked into the screen and stop the fuel from getting through. If it was a starter or coil, it would not start at all.
Dec 05, 2008 | 1984 Ford Bronco II
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
