Kenmore 22822 Canister Vacuum
Problem for Kenmore 22822 Canister Vacuum
Kenmore cannister vacuum tube - reattaching connectors
By jamesHose on Mar 27, 2008
Any thoughts would be helpful...
I have replaced the connector that connects to the cannister and the tube. I was able to wire everything up and test, but now despite large efforts of pulling / pushing I cannot get the clips to click. Any ideas?
Thank you for any help!!!
Comments:
Mar 27, 2008
- That was it - heated up the neck and the clips directly, and then squeezed the suckers together.
Thank you very much!
Best Solution
posted on Mar 27, 2008
Very Helpful)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1782 votes
Make sure that the two prongs that go over the hose are going in the correct slot in the cuff. If in the wrong one, the cuff won't snap into place. I have had to slam the end of the hose on the work bench while holding the cuff to push it all of the way on. Some I have heard warm up the cuff in hot water or a hair dryer to make it more pliable.
Comments:
Mar 27, 2008
- You are welcome.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22822 Canister Vacuum
Questions and Unsolved Problems for Kenmore 22822 Canister Vacuum
Do you recommend Kenmore 22822 Canister Vacuum?
Answer
Answer
We got the hose replacement and put it back together and it worked until we turned the hose. 3 of... (More)
Answer
Hi, This is probably a clogged line somewhere in the machine... but if I could get any tips on... (More)
Answer
The hose that connects to the vacuum cannister has broken. The plastic clip that holds it ionto the... (More)
Answer
While vacuuming the other day, the head continued yet the canister failed sucking... seems no power... (More)
Answer
Replace the hose it shows in the manual it can be replaced. kenmore canister model no. 116.27112790
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
