Question about Kenmore 24 in. 16019 Built-in Dishwasher
White film on all dishes and silverware
Just startes I have a water softener and its seems to be working fine. All of a sudden all dishes are covered with white cloudy film. I cleaned the dishes with clr and it takes it off. Is there something wrong with dishwasher? I have a stainless steel kenmore elite push button dishwasher about 7 years old.
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on May 08, 2010
2 Suggested Answers
SOURCE: White film on all dishes and silverware
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Posted on Sep 10, 2010
My dishes are coming out with a kind of film on them -- especially the silverware and glasses. Now the plates even look like they have a film on them. The dishes are often still dirty.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 13, 2011 | Bosch Dishwashers
The dishwasher is working, but there is a soap like film left behind on the dishes, glasses and silverware. It's a Kenmore dishwasher.
Hi
Daniel
Jan 07, 2011 | Kenmore Dishwashers
I am getting a white residue on our dishes all of a sudden. I have a water softener which seems to be working, but can't tell which is causing the problem (dishwasher or softener)
Hi
Daniel
Jan 07, 2011 | Whirlpool Dishwashers
White build up on dishes and silverware that wont rob off
Hi
Daniel
Dec 11, 2010 | Dishwashers
Apr 27, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
Soap residue on glasses & silverware
Try changing the type and brand of detergent as some are better than others. Could the water softener need service? If you wash/rinse any dishes in the sink, do they have the same problem? Good luck!
Apr 06, 2010 | Dishwashers
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Dishes, glasses & silverware have white film, look unclean!
May 11, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
White film inside the dishwasher and on dishes
Usa a liquid detergent and rinse agent. Make sure your water is above 120 degrees. If you are a hard water area, use a detergent containing a water softener.
Mar 25, 2009 | Siemens 24 in. SL34A006UC Built-in...
Kenmore 24 in. 16019 Built-in Dishwasher Logo
280 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
