Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
The clothes are still wet after the spin cycle. The washing drum turns with a lot less effort when I turn it by hand leading me to suspect that I have a broken belt.
Would you please let me know if this is the case and how to go about fixing it myself. Specifically how to remove the Washing machines cover so that i can get to the suspect part.
Thanks,
Kris I opened the back of my maytag neptune washer and the belt has fallen off. I tried to put it on but it seems to slip off as I rotated it. I don't see any motor isolators but then I don't know where they would appear.
Also, I found muddy water on the floor of the machine; wires are sitting in the water! The water looks clay-like even though I live nowhere near clay! There is a lot of dry "clay" as well, as if it's been collecting for a long time.
  • jackandryans May 19, 2008
    same problem here!!! I had a problem with the machine not draining last week and called a repairman who charged $185.00 to put a new part in; took all of 10 minutes to do, too. Now, days later, the clothes are still wet after cycle finishes!!!
  • 41 Answers
Sounds like your bearings have gone in the back of the drum and damaged your water seal. the clay type substance is possibly water mixed with grease.
Posted on Sep 03, 2009
SOURCE:
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
Clothes are still soaked after spin cycle
What is the model number of your unit?
Nov 18, 2012 | Estate Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
If the drum spins in the spin cycle, then the belt can't be broken. However, if the drum does not move at all in wash and spin, then the belt can be broken or just fallen off. You will have to remove the back plate and fit the belt back on the drum pulley and the motor pulley. If belt is ok check the motor brushes, they could be worn. They are located one on either side of the motor and identifiable by a single wire that connects to each one. You could also have a restriction in one of the drain hoses which is not allowing all the water to drain out.
Nov 05, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
442 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
