Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
My Samsung PS4297HD TV started to turn itself off
My Samsung PS4297HD tv started to turn itsel*** after about 5 minutes and noe wont turn on at all but just makes a constant clicking sound
2 Suggested Answers
freelance-au
  • 131 Answers
SOURCE: My Samsung PS4297HD TV started to turn itself off
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Posted on Apr 05, 2010
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
My Samsung PS4297HD TV started to turn itself off after about 5 minutes and noe wont turn on at all but just makes a constant clicking sound
Hi
Hope this helps
Apr 05, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung LNT5265F
I am having the exact same issue with an LG42LB5D... anyone have any thoughts?
Dec 24, 2007 | Televison & Video
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
