Question about Electrical Supplies
Gen runs for 8 min then shuts down most of the time at times runs like nothing wrong. New fuel line filter pump fuel tank cleaned oil level good and clean.
  • 5,603 Answers
Is oil pressure good? Check it when it shuts down.
Most of these have a switch that kills it if pressure drops. At operating temp the pressure may drop.
Posted on May 09, 2010
Ford truck
Do you have 2 gas tanks?
Jun 21, 2017 | Ford F-150 Cars & Trucks
My rs 125 runs fine for a min then looses power and gradually gains it back, when i got home i noticed spots of black oil down at my foot pegs, is this a sign of needing a re build?
Hi, Adam you may have squeaked your top end this is commonly known as "HEAT SEIZE" the piston heats up expands and becomes extremely tight in the cylinder bore and usually occurs mainly on 2 cycle engines right after a fresh top end rebuild, but it can also happen to brand new motorcycles, these are rare instances due to better quality control and education. Overheating failures that cause pistons to seize are many and each one should be carefully diagnosed to prevent future repeat offenders and the usual suspects are:
1. Loose fasteners causing intake or base gaskets to leak or crankshaft seal failure caused by age, overheating, or walking.
2. Improper assembly of reed valve gaskets.
3. Improper oil/fuel premix ratio.
4. Broken, pinched, or cracked fuel line.
5. Carburetor fuel passages clogged or restricted from stale fuel varnish, ethanol sludge, dirt, rust, or fuel level in float bowl too low.
6. Main jet size too small.
7. Air filter improperly installed, missing or not sealing.
8. Faulty or improperly adjusted oil pump and or cable.
9. Failure to bleed oil pump after running oil tank dry, rebuild of pump or replacement
10. Among the causes of lack of cylinder, lubrication is clogging of lubricator by dirt or waste, obstruction in oil pipes/lines, leaky check valves, leaky pump packing, broken oil pipe/line, oil too cold to feed.
11. Wrong type of oil used in premix or oil tank
12. Improper spark plug heat range (too hot) and or gap.
13. Ignition timing retarded, faulty CDI.
14. Excessive engine load, brakes dragging, clutch slipping, transmission lubricant level too low or viscosity to high.
15. Engine coolant level too low, too old, or improper mixture ratio.
16. Engine coolant pump failure, damage, or passages restricted.
17. Radiator clogged, fins damaged, or faulty cap.
18. Failure to follow proper break in procedures.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2004 Aprilia Rs 125
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 12, 2013 | 2004 Aprilia RS 125
Why my bajaj pulsar Accelaretion gets slow suddenly and shuts down and dont want to start
Hi, Ravi_ali you may have squeaked your top end this is commonly known as "HEAT SEIZE" the piston heats up expands and becomes extremely tight in the cylinder bore and usually occurs mainly on 2 cycle engines right after a fresh top end rebuild, but it can also happen to brand new motorcycles, these are rare instances due to better quality control and education. Overheating failures that cause pistons to seize are many and each one should be carefully diagnosed to prevent future repeat offenders and the usual suspects are:
Documents matching bajaj pulsar 150 Scribd
May 25, 2012 | Bajaj Pulsar 150 Motorcycles
I have an 1996 f250 powerstroke and it is running rough.
The most common problem is a bad fuel injector but if you haven't already done so--check to make sure your oil level is all the way up to full.Power Strokes use a high pressure oil pump to operate their injectors and if your oil is at a low level it can cause air pockets in the lines going to the injectors.It's not a real common problem but I 've seen it happen maybe 10 times.Another cause is using the wrong kind of oil.Some oils have a tendency to foam at high pressures and can produce air in those same injector supply lines. Good luck!
Mar 01, 2010 | 1996 Ford F250 Crew Cab
66 mustang engine running out of fuel
Do you have any of you fuel lines close to the exhaust? (vapor lock)
Mar 24, 2009 | 1966 Ford Mustang
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
Long rest
OK, this is what the StreerRodders face all the time.
1) Pull all the plugs and get new ones ready.
2) Drain the Oil and replace with 10W-30 with new filter
3) Check the water level in the radiator - make sure up to level
4) Put several ounces of sea-foam down each cylinder
5) Hand crank engine over several times
6) Use starter motor to spin over motor several more times
7) Put Spark Plugs back in.
8) Make sure fuel in fuel tank is drained
9) Add new premium fuel - Use an air hose to clean the fuel line to the engine
10) Pump through new fuel by loosening the fuel line by engine and pumping a bunch through - hook back up tight.
11) Try starting engine -
12) If Carb engine use a bunch of carb cleaner in the carb before starting to clean out most or junk
13) Once engine is started monitor oil pressure and temperatures carefully - run for about 10 minutes
14) Stop
15) Drain Oil - replace filter again - put in new synthetic oil - recommend Amsoil 0-30W
16) Drain radiator and flush out -
17) Reset radiator fluid and top off.
18) check for leaks everywhere
19) Start again and drive carefully for 100 miles and you should be good to go.
Regards,
Doug
Jul 31, 2008 | 1992 Mazda MX-5
Electrical Supplies Logo
99 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
